cleanmycorolla
- Apr 27, 2012
- 3,805
UWW+ is definitely the most used product in my arsenal. There is no more versatile product at any price point!
:iagree:
Only product I've used since this review that has the versatility and the quality of UWW+ is Gary Dean's Infinite Use Detail Juice. However, it's a bit more costly.
Cost not an issue, which would you pick and why?
Hi Bill.Just had a thought...
UWW+ is boosted by Polycharger. Why doesn't it gel and/or become hard?
In other words...
Why does the Polycharger you buy have a very short time frame to use it with whatever product you mix it with, and not react in the same manner when boosting a product like UWW+?
Certainly others have thought of this as well.
Could someone compare this to OOC?
http://www.autogeekonline.net/forum...imum-opti-clean-vs-ultima-waterless-wash.htmlCould someone compare this to OOC?
I haven't used UWW+ in a while for whatever reason. I've been using other rinseless and waterless products. I did get a chance to use it yesterday, pre treating panels using it at waterless concentration, then cleaning them with a rinseless concentration of the product.
UWW+ not only cleans, but it protects against UV and the elements.
Why do I like this product so much? For the same price (OR LESS) than many others are selling a 32 oz bottle of RTU (ready to use) waterless wash, you can buy a whole bottle of UWW+ concentrate and make 704 oz of waterless wash. That's SEVEN HUNDRED AND FOUR vrs THIRTY TWO.
How much is 704 oz. how about a visual. Each gallon is 128 oz. 128 x 5 = 640.
[128oz (1 gallon) x 5] + 32oz(x2)= 704oz
Imagine ALL these bottles filled to the top. That's how much UWW+ waterless wash you can make from one 16oz bottle.
This is 704 oz:
Cost (assume all bottles are filled with UWW+ [waterless concentration] and water is free) : $20.99
Now, say you decide to buy 32 oz of RTU waterless wash. You will get this much (assume bottle is full):
MSRP: $22 for 32 oz. (not picking on Croftgate, I just knew their RTU waterless was priced close to the concentrate of UWW+ - many others are around this price)
That is what 32 oz looks like.
Not only that, but UWW+ works excellent as a rinseless wash as well. In fact, you will use LESS of it than other rinseless washes, because the dilution is less: 1oz : 3 gallons(Ultima) vrs 1oz : 2 gallons(others)
Now, whenever I use a rinseless, I pre-treat the panels with a waterless. UWW+ is perfect for this, because its one of the few products you can use for both. So, you are using the same chemical and the rinseless and waterless work excellent together.
Compared to the newest version of the "original" blue rinseless, I find it MUCH slicker and easier to dry. It may be the best rinseless/waterless out there. This really comes to play in colder temperatures where I find other rinseless washes just don't want to "flash" and become dry. I don't seem to have this issue with UWW+. I find even if you use it "heavy" (higher concentration) it still performs excellent. No streaks, no smears, and leaves a glossy very slick surface.
Also, when talking about this product, it's rarely mentioned the protection it leaves behind. UWW+ is boosted by Polycharger, which to my knowledge will help extend its polymer protection.
I know everyone reading this knows how to do a rinseless / waterless wash, so showing pictures of a clean panel is a waste IMHO. Any rinseless will clean a panel. I believe marring a panel during a rinseless / waterless wash is more a function of technique, towels used, and how dirty the car is - than what rinseless product is used (assuming a quality product is being used)
I'm more concerned with:
-versatility of the product: UWW+ excels at rinseless, waterless, spray wax, quick detailer, and clay lube uses
- ease of use
- protection / beading left. It's not just a "wash" it does boost your LSP and leave some noticeable protection behind in my experience. This is why it works well as a spray wax / wax booster.
- cost $$$
So how does it work? Yesterday I washed my SUV using UWW+. I used no spray wax and my regular wax is about a month old.
It's raining today, so I took some pics of the beading provided by UWW+ on different surfaces:
This last pick you can see several surfaces: glass, plastic, rubber, and paint. UWW+ is beading well in all of them.
So what is the downside to UWW+? Nothing is perfect, there must be something that could be improved? Right? No. Nothing. From the cost, to the packaging, to the produc'ts performance - I could find no way to improve this product. No one little issue.
It even smells pretty good and I like the green color:
Even the packaging is great, as it has a measuring device built into the bottle:
I reccomend UWW+ to anyone:
- looking for an excellent waterless / rinseless. Maybe the best at both. There is no compromise in performance of either function. It maybe the slickest product out there for waterless and rinseless washing.
-trying to simplify their product purchases, since it is one of the few products that can be used as a waterless or rinseless.
- trying to save a few $$$. As you only need to buy on bottle - one product - to use as a waterless, rinseless, quick detailer, spray wax, or clay lube. Again, its not a "compromise" using it in any of those functions. It performs better than most dedicated products in those categories.
Thanks for looking. Feedback / comments welcome.
I love UWW for all the reason you listed! It's awesome in every way IMO. I spray panels with UWW or Opti-Clean before using a rineless also.
