Thanks for the review Mike! Tried this out today and was happy with the results. Felt a bit more slick than the regular Uber Rinseless (my current go-to rinseless), and left a nice shine. I did find it a bit streaky in some spots (which seems to happen with SiO2 products), but that’s on my dark grey car that lives outside all day in the California sun, so things tend to streak on it generally.
I will say, per use it’s quite a bit more expensive (relatively) than the plain Uber rinseless, mostly due to the different dilution ratio. If this costs about 25 % more per 16oz than Uber, and you cut 1.5 ounces of this per 3 gallons of water (whereas regular Uber is only 1 ounce), then this equates to roughly 88 % higher cost per wash. Do you know how set that 1.5oz / gal dilution ratio is, or can you dilute it a bit further? Granted, a 1:256 dilution ratio is pretty standard for a rinseless wash, so maybe it’s just that the regular Uber is extra concentrated / can be diluted more than most other rinseless options.
Thanks!
