richy
- Mar 27, 2007
- 5,158
Well, I pulled a really boneheaded move last weekend. While backing into my in-laws' driveway one night (while it was raining heavily I'll add in my defence), I scratched the right rear 1/4 panel and RR door against their big (and sharp) plastic garbage container. I tried a B/S yellow pad + 105 first and although it improved it, the combo was not giving me the correction I needed.
So, I've been saying that I would do a video showing my technique with using the Flex 3401 + TB black wool pad (and + M105 in this case), so I went ahead and did it. This is also the first video I shot using my new Nikon D7100.
Here are some shots of the damage I inflicted upon the paint. Scratching one panel wasn't good enough I guess....loser!
Now that you see what I had to correct, check out the video. As stated in the video title, I used my Flex 3401 + black Tuf Buf wool + M105. Every area got one pass, except for the area that was first done with the yellow B/S which technically got two passes including foam + wool. Afterward, the panels were polished with Flex + M205 + white B/S and then for giggles, I also hit it with Reflect + Flex + blue B/S. That was followed up with DG Squeaky Clean + red B/S + Flex. One last honesty test of Eraser was also used prior to coating it with CQF. Here is the video.
Durango Scratch Repair with Flex 3401 - YouTube
After coating that area, the remaining parts of the car were shot with Permanon via a spray paint gun.
After Shots:
For some reason, the video link isn't imbedding the video into the post. Lord knows why??
After Shots:
