stilltipping3
- Jul 13, 2013
- 1,003
I always said I didn't want a rotary but after ur video I wouldn't mind taking it slow and learning. Seems to be a huge time saver! Thanks for the Video.
Good video and shows exactly how to use M105 correctly....
Works the same with a DA.
I don't think u put a DA at 1000 rpm and go so fast with the pass. But I also get dust so I obviously use it wrong. With a few drops and a 4000rpm and the pad given a few sprays of pad conditioner it does work better than using the product to prime it but I still get dust and its hard for me to remove. I do like the video though.
If it's dusting then it's too much product....
Put like 3 or 4 drops on the DA pad and rub it on the paint to spread it around, it primes the pad also, you can add a like a drop or two....
Then start the DA and work the area until it almost disappears, wipe off.
Then just use 3 drops and move on section to section.
Sweet
People get way to carried away with the pad priming thing and end up using way too much product....
And yeah if that happens it will dust like crazy.....
And then they complain about the dusting.....
When they used too much product in the 1st place...
For me it dust when I'm working outside, it doesn't when I'm inside. That simple. Thanks for the video, I cringed a little every time you buffed over that body line. You probably have a lot more rotary experience then me, I always thought that was a no,no.
Macomb Dents & Details: Car Detailing and Paintless Dent Removal
www.Facebook.com/DentsAndDetails
I may be slow, but I do poor work.
good information. Maybe this will stop people from using an ounce of 105 and complain about it dusting.
I've never had a problem using 105 because I only use what I need.
Also turn your phone sideways when making videos!
I work outside, in the heat, in the cold. It doesn't matter. People use way to much product....you are working Inside.....
I'm not trying to cut MP's grass here, but with all the bad press and discussion about how badly M105 dusts (it doesn't for me), that I thought I would shoot a short video to show my technique and what I do to prepare the pads so you get the desired results. M105 continues to blow me away with its capabilities! Check it out:
(If you guys want, I will shoot another on a black car showing M205 and possibly both products)
[video=youtube_share;wIEpxBe6oXQ"]Richy's Meguiars 105 video - YouTube[/video]
Is tis the video?
Thanks!.. I'm not sure though. I thought they were talking about his misting his pad with water and I didn't see him do it in this video?
