Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
- Thread starter
- #21
Red x's... yeah, I viewed the photos when this first was posted, but just wanted to take a look again now that I have the "same" car to work on.
Maybe they linked to another site that no longer hosts them... they are no longer on any company's site from what I see.
Hey jbgrant, I'm from PA, but live in IL now... we go to Bloomington all the time for the restaurants.:xyxthumbs:
Hey Mike, if I make a bottle specifically for a wet-sanding spray solution, should I just use 2-3 drops of car wash soap for the entire bottle or use a teaspoon or two of the car wash shampoo?
I do have a bottle, but I believe I used too much soap based on what you're saying. This post is some awesome information. It's amazing the kinds of things you don't think about (like cutting sand paper into small pieces) when you get into the heat of the moment trying to remove a few RIDS.
I've been using a form of your feathersanding when I wet sand, but not to the specific directions you provided here. I'll start using your method as it makes a ton of sense and will hopefully make removing the sanding marks and scratches a lot easier.
Thanks for the informative post.
Bump...in case Mike never read the above post.
I've been using a form of your feather sanding when I wet sand, but not to the specific directions you provided here. I'll start using your method as it makes a ton of sense and will hopefully make removing the sanding marks and scratches a lot easier.
Thanks Bill....
Just a drop or two for a 32 ounce spray bottle of water. You want just enough soap to provide lubrication plus anit-loading of the disc with paint particles but you don't want to create suds as you sand.
Glad it helps....
For everyone reading this into the future, keep in mind when I wrote this article and used this technique products like the 3M #3000 and #5000 Trizact Sanding Discs had NOT been invented yet.
Dampsanding with 3" Griot's Garage Mini Polisher
Griot's 3" Mini Polisher works great as a 3" Dampsander
Nor had the Rupes TA50 been introduced yet.
Rupes TA50 Mini Sander - First look...
Rupes TA50 Removing RIDS
Precision Buffing with the Rupes TA50 - It doesn't get any better than this!
Rupes TA50 Mini Sander with Meguiar's Xtra Cut MF Discs in action!
As I pointed out in another thread; the Trizact is an awesome solution that carries less risk than feather sanding. Having said that, there are still times were the feather sanding technique is better suited because you can even further isolate the defect.
Even using a sun gun I don't often see RIDS looking directly at the finish on my Sterling Gray Metallic paint. Rather it requires looking at an off axis angle to spot them.
The question I have is how do you know how far to go?
I don't own a paint meter and wouldn't know how to interpret the results. I know a big part of this is "experience" but can you elaborate any further on how you judge when to stop?
is it just me or did i miss what RIDS and LSP stand for?
I think the toughest part is knowing when to leave something alone I guess only experience will tell you that.
I sanded through the clear coat on the hood of my prior daily driver (2003 330xi) using 1500 grit. The car was already 7-yrs old (150K miles in Northeast winters) at the time and it didn't take much.
The ability to assess a defect is probably even more important than having the ability to remove it. A paint meter may help to some degree but you just never know quite how much it will take to remove something.
