Klasse Act
- Feb 21, 2012
- 27,705
- 2,735
As others have stated before i just use the leftover solution after im done with the body panels. Depedning on how dirty everything is i'll either spray some APC on the tires and wheels or just use the solution to clean. If i end up using a APC or wheel cleaner i will agitate with a brush and then rinse everything off with the rinseless solution. I think i get better results than soap and water since a rinseless can be done in the Texas heat without much water spotting, everytime i use soap i get water spots .
The last sentence is everything you need to know about rinseless wash
