Klasse Act
- Feb 21, 2012
- 27,873
- 3,002
Have you tried both methods? If so, which one do you like best?That's what I started using rinse-less/water-less products for too, door jambs, engine bays ect.
While I still feel safer using lots of soap and lots of water, I'm slowly gaining confidence in rinse-less for paint.
I think the key with rinse-less is thinking on your feet, as in don't just treat every wash the same or follow a set routine. Sometimes you will need more pre-soak, sometimes you will need to use more towels or more frequent dunking, sometimes you may need to pre-rinse the certain areas, sometimes you only need the basics.
