rinseless wash supplies
gregory1420
Member
i am new to the rinseless wash.. what are some of the things needed to do this?
already got the 2 buckets
some onr or something
what else?
do the BRS or microfibers works better?
I would get two buckets and some grit guards. One for wheels and one for paint.
I use the BRS with the ONR
With other rinseless like the new McKee's one I use a wash mitt.
Of course towels.
I would purchase these supplies
*Two buckets with Grit Guards and Gamma Seal lids
*25 Microfibers
*Waffle Weave Towel
*ONR wash and Shine
*Big Red Sponge
*Optimum Blue Waffle Weave Sponge for tighter areas
*Opti Seal for drying aid and sealant all in one
*Hand Held Pump Spayer for pre soak with ONR mixed at 128:1
I prefer 2 buckets, one grit guard, and a couple Ultra Soft Microfiber Rinseless Wash Mitt, and a good drying towel or two.
It's hard to pick your first rinseless. Most all of them are pretty good, you can't really go wrong with the ones I've seen sold here.
Pick your flavor!
I was wanting a rinseless that doesn't leave anything behind.. looks like D114 fits that bill.. might try that..
I use three bucket. 1 solution, 2 rinse. All with grit guards
I have 4 rinseless mitts
Ultra Soft Microfiber Rinseless Wash Mitt.
For rinseless I have found the to be outstanding @ 1oz per gallon.
CarPro ECH2O Waterless Wash & Detail Spray 1 Liter.
For drying I use either one of these.
Big Blue Microfiber Drying Towel, 26 x 18 inches
GYEON Silk Dryer 20 x 22 Inches
Use the Ech2o at 1 oz per gallon for the solution.
Soak microfiber mitts for a few.
Perform rinseless wash and change out mitts if needed. 2 rinse buckets for the mitts keeps the solution clean as well as the mitts, but sometimes when covering areas that like to accumulate brake dust and other areas such as the rear, I might switch them out even if they look clean.
Drying I use Ech2o mixed as a detail spray with either some reload, or Gyeon cure in there as well. I have a 48oz sprayer for the detail solution. The mix is 2 oz Ech2o, 2 oz reload or cure, 40 oz distilled water.
Spray dry drying media with a couple sprays and dry the car.
thanks for the link.. that stuff looks pretty good.. it also looks like it doesn't leave anything behind also..
It does not from what I could tell using the beta version. ONR leaves a little polymers behind but not enough to hinder the performance of one's LSP. CarPro Ech20 leaves SiO2 behind.
Why would you not want use the Big Red Sponge with the Mckees N-914?
The big red sponge was designed to work with ONR. Can it be used with McKee's? Probably. Is it going to be effective? Well I can't answer that either. Someone is always welcome to try it out. I will stick with a some sort of wash mitt with McKee's as I had success using one with the beta sample I have.
*25 Microfibers
*Waffle Weave Towel
*ONR wash and Shine
*Big Red Sponge
really? does he really need twenty five microfibers to start rinse less washing? that seems quite excessive for one car.
the new rinseless wash mitts are excellent even for regular washing. they rinse out unbelievably easyly
C'mon man, it's a sponge. Do you think they invented a new foam for Yvan? I guess Yvan is a pretty good salesman, if he's been successfully selling that a BRS only works with ONR because that's what it was "designed" for, and that microfiber towels melt at 140F. Maybe he should run for office.
Just for a reality check a typical rinselss wash, once you dilute it for use, is 99.6% added water. I think if a sponge works with one 99.6% water solution, it's going to work with another one.
Which mitts are you referring to?
Probably these: Ultra Soft Microfiber Rinseless Wash Mitt
You are more than welcome to try. The BRS brings up the issue of another member who had issues using the BRS with D114. N-914 has a similar behavior as D114.
