Just some advice not sure if it's been mentioned here or not....if you're using more than one bucket....for example the 2 bucket method.....you should make sure the rinse bucket isn't just plain water, it should be the same ratio as the wash bucket. All these rinseless companies whether it be McKee's, or ONR or whatever have put a lot of research into their dilution ratios. If you're taking your sponge and putting it into the plain water to rinse it then back into the wash bucket (which contains your rinseless sollution) you're inadvertently changing the dilution ratio in the wash bucket. The sponge is absorbing plain water and you're transferring it to the wash bucket. So as you go through your process, each time you put the sponge into the wash bucket you're slightly altering the ratio, over the course of the wash you're wash bucket is becoming increasingly more diluted.
Sent from my SAMSUNG-SM-G930A using
Autogeekonline mobile app
