Marc08EX
- May 10, 2008
- 4,108
- Thread starter
- #21
Thanks for sharing your thoughts everyone! It's sincerely appreciated.
The reason I ask is because I wanted to know how much solution is safe to use. I wring out my towels slightly but mine are still dripping as I'm wiping down the car. The drips of solution in the garage just makes a mess. If using less solution like how the manufacturers do in the videos I posted is still considered safe, then why not? It would produce less mess in the garage and you can prolong the use of your rinseless wash solution.
I'm sure that's for demonstration purposes only.
Like I mentioned above, I also like my towels to be dripping and holding as much solution. But it makes a big mess in the garage.
So as you're flipping over the different sides of the towels, do you add more rinseless solution to the towel? Of course you won't be dunking it back to the solution bucket..
I agree with this but doesn't this defeat one purpose of rinseless - to save water? If I'm pulling out my pressure washer or a hose, then I'll just do the traditional wash since I already have those out.
2. I'm not sure why you would start *any* type of wash on the middle of the vehicle.
3. Since RW and water are cheap - I say use as much as you want. What harm could a drippy wet towel do?? I use the towel as wet as I can get it.
4. Pressure washing (or even hosing off) the vehicle before you touch it will make a wash much safer than worrying about how much solution you use on your towel - regardless of what type of soap you use.
