Roadshow Detailing Class in Powell, Ohio - September 14th & 15th
Date: Saturday and Sunday, September 14th & 15th
Time: 6:30am to 6:30pm
Location
Detail Pro Shop
6040 Glick Road
Powell, OH 43065
Mike Dilger, owner of Detail Pro Shop will be hosting our class at his shop in Powell, Ohio.
Hands-on - No chairs
Our classes are unique in the industry as they are 100% on your feet, hands-on training. There simply are no chairs. If you learn better by sitting in a chair and listening to someone talk then you'll need to find a different class.
How to sign-up?
> Click here to sign-up online <
Or
Call Andre and sign-up over the phone
1-800-869-3011 x244
Hope to see you there!
More...
Autogeek's Roadshow - Saturday & Sunday Class Outline
Saturday - 6:30am to 6:30pm
Morning Session - Multiple-Step Paint Correction
1: Extreme Washing - This class session covers all the correct tools, products and techniques to thoroughly clean and prep a car for detailing when using a source of running water.
This includes,
  • Foam Guns
  • 3-Bucket Wash Method
  • Wheel Woolie Wheel Brushes
  • Speedmaster Wheel Brushes
  • Brake-dust Removing Wheel Cleaners
  • Mechanical Decontamination using Nanoskin Mitts & Towels
  • Chemical Decontamination using Iron & Fallout Remover
  • Tools for machine scrubbing tires
  • Tools for air drying cars
Also covered in the morning washing session are the non-washing procedures to do and the correct order to do them in.
  1. Wet Wash Engine Detailing
  2. Machine Glass Polishing
  3. Headlight Correction
2: Car Inspection & Prep
This class session covers everything you need to do to a car BEFORE you start machine polishing. This includes inspecting using an Vehicle Inspection Form, Paint Thickness Gauge, Swirl Finder Lights, Baggie Test. Plus what to tape-off and how to correctly tape-off and cover-up trim, comments, tops, etc.
3: How, why and where to do a Test Spot
One of the most important steps if not THE most important step everyone should be doing before detailing a car.
4: 2-step paint correction and polishing
This class session covers all the professional techniques to correctly compound and polish paint to perfection. Multiple-step paint correction is called, show car detailing because you're breaking the paint polishing process down into isolated and dedicated steps to maximize the end-results for a true show car quality finish. This session includes tools from,
  1. FLEX
  2. RUPES
  3. Griot's Garage
  4. Meguiar's
  5. Makita
  6. Porter Cable
  7. Cyclo
Pads - Products
The morning session includes a wide range of pro-grade compounds, polishes and buffing pads for a very well-rounded experience. You will learn how to know when to use a compound versus a medium, fine or ultra fine cut polish.
Ceramic Coatings - Waxes - Sealants
The morning session covers proper techniques for chemically stripping paint for the installation of ceramic coatings specifically. Techniques for applying and removing traditional carnauba waxes and synthetic sealants are also covered in the morning session.
5: Final Steps
The morning session covers coatings and dressings for; glass, tires, rims and plastic trim.
>Lunch Break<
Lunch and cold beverages are provided
Afternoon Session - One-Step Detailing
One step detailing is also called production detailing. In this session you will learn which types of cars and other projects are best suited for an AIO type product, (All-in-One), also called a cleaner/wax. The focus on this class is how to restore a neglected car's finish to like-new condition in only one step. Also called Speed Detailing. This type of detailing is great for enthusiasts taking care of their own daily drivers or for professional detailers for their budget package and also things like dealership work.
1: Washing Techniques for Waterless Washes and Rinseless Washers
The afternoon session covers how, where, when, why and what for using either a waterless or rinseless wash. Correct techniques for both types are covered and when to use one over the other. Also covered are the correct types of wash media and other tools needed to clean a car without running water safely.
2: Mechanical decontamination - Why and how to use detailing clay and clay substitutes
Students learn the proper technique for using detailing clay as well as clay substitutes.
3: Taping-off and covering up to save time and marketing purposes
Students will build on the foundation created in the morning session as well as learn the marketing side of taping-off and covering stain-sensitive surfaces.
4: One-step high quality detailing
Where the morning session goes over how to use a multiple-step approach for show car results, the afternoon session covers how to correctly use All-in-One products to compound, polish and protect the paint in one-step. This type of detailing is perfect for entry level detailing packages as well as daily drivers, budget details, RV's, and large vehicles like trucks and vans where the owner or customer does not want or need a ceramic coating. There are dos and don't when it comes to this type of detailing, which you will learn in the class. Everyone should have the skill set and knowledge to correctly perform one-step detailing jobs whether you're an enthusiast or you detail for money.
Tools - Pads - Products
I call this free-for-all. Students can choose and use any tool and pad combo they previously used in the morning session. This is your opportunity to spend more time with any tool that has attracted your interest and attention and you're thinking about investing in. You can even use multiple tools, it's your choice. The importance of abrasive technology is stressed in this class as well as how to under-promise and over-deliver exceptional results. You will learn how to get show car results in half the time.
Sunday
Morning session - Wetsanding an entire car from start to finish
If you have ever wanted to know the art of wetsanding, here's your chance to learn from beginning to end, exactly what to do. This is a real-world class where you will work on real cars and this is the BEST way to learn the entire process from start to finish.
This class includes,
  • How to prep a car for wetsanding
  • Hand sanding techniques
  • Machine sanding techniques
  • How to correctly use a rotary buffer to remove 100% of the sanding marks
  • How to finish out 100% hologram and swirl free using any orbital polisher (your choice which orbital polisher to use)
  • How to seal the paint using a ceramic coating, carnauba wax or synthetic sealant, even the cheater technique of using an AIO.
>Lunch Break<
Afternoon Session - Interior Detailing
You will learn the difference between a hot water extractor and a steam machine and when and how to use one over the other.
This includes,
End of day
Certificate Award Ceremony
Class wrap-up
Book signing
I'm trying to gather the funds to attend this class. When I saw there would be one in Ohio, I've been aimed at going ever since.
But until the funds are definitely available, I just can't commit. I sure hope I can get there!
Completely understand. And for you and everyone that will read this thread into the future, if you sign-up 30 days before the date of the class you get a $100.00 store credit.
And - with the new Autogeek Reward Miles - the price of the class is equal to the same number of "miles".
So a Roadshow Class at $895.00 = $44.75 in Autogeek store credit. If you sign-up early you get the $100.00 store credit for a total of $144.75 - that's better than paying $895.00 and no Autogeek spending money.
The below is taken from this thread,
Introducing Autogeek Reward Miles
Get Rewarded!
Use your reward miles by redeeming them cash off your next order and more!
$5 Dollars Reward Coupon - Redeem for 100 Miles
$10 Dollars Reward Coupon - Redeem for 200 Miles
$25 Dollars Reward Coupon - Redeem for 500 Miles
$50 Dollars Reward Coupon - Redeem for 1000 Miles
$100 Dollars Reward Coupon - Redeem for 2000 Miles
Just throwing that out there. Anyone that's looked at any of the pictures of the 2-day roadshow classes I've shared in the past knows how busy and hands-on they are. If you really want to go to the 2-day class, I'd highly recommend doing what you have to do to get to one.
It's possible they will be reduced to 1-day classes moving forward. The price will be less but you won't get to do ALL the things I show you doing at the 2-day classes. There's just not enough time to do it all and currently the first day is a 12 HOUR DAY!
Get Rewarded!
Now that’s Value with a capital V!!! :props:
What a great looking location too, a sweet looking shop Mike has there.
12 Hours of learning & actually properly detailing cool cars in the process ... I recommend a good nights sleep & a hearty breakfast in the morning, it’s gonna be go go go. :buffing:
Aaryn NZ. :dblthumb2:
***Update***
The pallet from Colorado arrived back to Stuart last Friday. We've been closed since then.
First thing today, I'm unpacking, washing pads and towels, topping off all the liquids and then packing for this class.
I'm only packing tools for the number of people signed-up.
1 of each tool for each person, that's around 10 tools per person. If you plan on attending get signed-up before Thursday as that's when the Ohio pallet is shipping out.
Click this link to sign-up online
Autogeek's Roadshow Detailing Class September 14th & 15th in Powell, Ohio
Or call Andre to sign-up over the phone
800-869-3011
x244
If Andre doesn't pick up the phone, he's probably busy as we're playing catch-up from being closed for Hurricane Dorian. He's GREAT at returning voice mail. Just leave your number slowly as this is the polite thing to do and you make it easy for another person to WRITE down your phone number.
:updated:
2 more cars confirmed for this class
1967 Ford Fairlane
70% of the car has the original single stage paint
1989 911 Carrera 4
Working on a few more.
I need a lot of cars for my classes because YOU work on cars. You don't sit in chairs.
Is it too late to sign up?
I just saw this and would love to attend!!
Welcome to Autogeek! :xyxthumbs:
Absolutely you should. From first hand experience (I’ve flown from New Zealand for a Mike Phillips Class) you definitely won’t regret it. Mike runs the most comprehensive detailing class on the planet, they’re proper hands on classes with the finest tools in the industry & you get to work on cool cars whilst having a bunch of fun as you learn . . . . Sign up. :props:
Thanks for the first-hand testimony Aaryn,
And I'm happy to say he has signed-up and he'll get to find out first-hand, just like you did, how much fun the classes are and also educational.
Nice!!! That’s too cool! :props:
eldemijw joins the Autogeek Online Forum & also signs up for a Roadshow Detailing Class with Mike Phillips in under 24 hours . . . :urtheman:
I look forward to reading your thoughts on the Class eldemijw. Enjoy! :buffing:
