fishnugget
- Sep 9, 2010
- 292
- Thread starter
- #41
Well its glad to hear I wasn't the only one using more m105 than m205. If only m105 worked the same as m205
When you owned your black car did you do a spray and wipe or just leave it alone and wait for the next car wash? Reason I ask is because the last thing I want is to add swirls.
My last black DD was GM and didn't suffer overly soft clear. A run of the mill QD and decently soft MF worked fine. I wasn't as knowledgeable nor detail-oriented then though so it may have looked like crap and I didn't notice.
Now, you want to talk about soft CC... I've been beating my brains trying to figure out how to finish and maintain Harley's Vivid Black. Just wiping off polish residue with my plushest MF leaves marks. :doh: Even IF I got the finish I was looking for wiping off dust with a high lubricity QD left marks. I finally discovered using a finishing polish like 85RD with LC orange gave the best results, believe it or not! And wiping off polish residue required a liberal spray of QD and wiping with only the softest of Waffle Weaves! In order to remove road dust I use ONR at higher-than-QD strength with the WWs. So I get done and finish with FK425 and I leave marks.I generally remove those by hand and since the metal tank is the only part of the paint that's problematic I'm the only one who sees them.
I'm thinking the next bike will be rattle-can bedliner black. End of problem. :surrender:
TL
Its funny how anal we become from all that attention to detail but its hard to let go from having worked so hard on our cars/bikes. I never would have imagined wiping with an MF would leave such bad marring/scratches on soft paint.
I have been hearing good things about 85RD and would have purchased it but many said the m105/205 combo would be enough. Luckily, TypeR was kind enough to send a sample my way.
I too find that my blue waffle weave similar to Detailimage are much softer than the plush microfiber and even the green guzzler WW's, just something I noticed. I used those also for polishing when I ran out of MF's.
The tried and true doesn't always work in all situations, sometimes you have to think outside the box.
Nick Chapman had a post on MOL last year about tearing his hair out trying to get 205 to finish without marring on a super-soft black Colorado. He tried every combo of polish and pad in his arsenal with no luck. This is a very experienced and talented detailer! Finally he tried the only pad he hadn't used yet and got incredible results using 205 with a yellow LC.. a pad that's aggressive and usually leaves marring that you need to polish out with a finer combo. That post got me experimenting on my soft clear and eventually finding a recipe that worked.
Other highly respected detailers have been using red LC and 105 to finish... a soft pad and an aggressive compound. Who woulda thunk it?
Just goes to show there's more than one way to skin a detail job and sometimes you're the test pilot.
TL
I have very soft black paint, this thread has me rethinking my finishing techniques... I also find it very hard to maintain this car 100% scratch free.
The rotary is faster but mistakes are murder. The da is much safer. Try the yellow pad, if that does not work, than u r not detaillling, it is bodywork. Tip for black car, wax every week.
Hey Indianaryan,
Chris meant to wax my car each time I wash it. He says that should increase my chances of preventing swirls. I think my problem came from not loosening the dirt on the car enough. I am going to give it a thorough rinse the next time I wash it and possibly invest in a pressure washer.
I believe that the less you touch your car the less swirls your going to have, especially on soft black paint like infiniti.
