Rotary for wax removal?
tooshort_128
I have a Chevy Tahoe and was thinking about using my rotary on a very low speed to remove wax to save time. I will apply by hand but thought about using the buffer at 300 or so rpm with a microfiber bonnet to remove. Thoughts?
I don't think that will save much time. What rotary do you have that spins 300 rpm?
I would so don't do it and it probably wouldn't save time either IMO.
How about washing in dawn dish soap and two bucket method. Finally dry and clay bar, then correct, then wax ?
Too risky I guess... Could introduce swirls or even mar the paint..
On a DA it would be fine tho.
I use my DA on it's slowest speed with my softest pad. And I put my softest microfiber towel between the pad and paint surface. I turn and change the MF frequently. It does a perfect job of removing the wax and I have never marred the paint.
If you feel the need to remove dry wax with a power tool, use a DA with a MF Bonnet.
what kind of machine are you using?
Most will apply by machine and remove by hand.
We need a little more info to steer you in the right path.......
Why would you use a machine/pad when many solvents exist? Car Pro or dawn dish washing detergent do it with a lot less effort and time.
DA'S are good for applying wax's and good for for removal of wax's
I think they meant buffing off the dried wax residue, not every layer of wax on the car. Or at least that's the way I read it...
On that note, I want to try some Eraser, I currently just use 12% IPA and that seems to work fine too for stripping polish/wax.
just apply the wax thinner and make removal by hand easier and faster. I hate using a tool to apply or remove wax. still need to use the hand with pad in sections like grille....bumper parts, etc. and it's alot easier and faster once you get some practice.
Yeah I'm not talking about old wax or wax residue. I'm just trying to save some time waxing my monstrous truck. Maybe I'll switch and use the rotary to apply the wax and remove by hand. I have a harbor freight rotary with settings from 200rpm to 3300 rpm. What pad or bonnet should I use to apply the wax? I only have orange and white LCD pads, terry cloth bonnets, and microfiber bonnets...
LC gold foam pad would be nice to apply waxes.
Red pad to apply wax, bare. Orange is way too coarse and white is too coarse also. You could probably use gold to apply wax as well. A rotary is really only for polishing out serious defects like heavy sanding scratches after wetsanding after a repaint. You should not be using a rotary to apply wax. Applying wax really isn't that difficult on a clayed and polished surface, and by using a rotary I think you are asking for more trouble than it is worth. You are considering using the wrong tool for the job. If you want to apply wax by machine, get a DA like a PC, and then use a MF bonnet to remove the dried wax.
I think it's wise to avoid absolutes here. Some people swear by finising with a rotary and others insist on a DA. The process of "jeweling" a finish before applying an LSP is specifically designed for using a rotary. I used the Flex PE 14-2 on Sunday to apply Liquid Souveran to my black Mustang. I used a Meguiars finishing pad. I removed the hazed wax by hand. It came out perfect. The advantage to using a rotary or DA to apply way is that you get a thin and even distribution of wax. No fingerprints in the finish.
If you have the skill, you can use a rotary to finish almost any paint, but some paints are so soft like black that you need a DA. A DA, like a Flex, always finishes hologram free with no buffer marks, but with that isn't always true with a rotary. That said, we are talking about wax application here, and not jeweling, and I would not use a rotary for wax or sealant application. A lot of people start with a rotary and finish with a Flex 3401. Based on that, I can't understand how it would be prudent to use a rotary to apply wax.
