Rotary VS Dual Action for Compounding
jslym777
Achieving results in less time - Assuming you know how to use both machines professionally and assuming you can use any pad/compound option, it seems as though using a rotary for compounding is still the most efficient way to go. (I am talking about compounding, not finishing.)
For full finish correction then, using a rotary, followed up with a DA for finishing - you yield best results using the least amount of time.
- Please chime in on your thoughts
The rotory may have you working backwards given all the new abrasive available today
Explain -
DA's can either be one of the following, but not both
- Safe, meaning it takes longer to compound as to not go through the clear as fast
- Just as unsafe, or more unsafe if it can compound as fast as a rotary
Well if you want to leave as much paint on the car as posable a rotory may leave its own damage on the paint that you will need to remove so the trick is to not let that happen. Not real good with links but their is a few good posts in here by Mike P on this subject
Some removal of hazing from a rotary is ok though since this is step 1 - compounding, also, we made the assumption that the handler is proficient with a rotary and knows how to use it without damaging.
Just doing the winter research my self but aiming to up my game in the spring good luck with your project
If you know that you are going to do at least 1 more step afterwards then I think yes, using a rotary for compounding is still the most efficient way to go.
Here's something to think about. In your post, you stated that a rotary to compound and then a da to polish will achieve the best result in shortest amount of time. That is probably true. But if I can get the same result with a one step with a long throw and an excellent levelling fluid, then I will have done it in a shorter time.
My point is, a two step compounding and polishing step is the norm for a lot of details but why do two when you can do the same in one? Also what is your ennvironment? Is this body shop work or is this vehicle beautification? A rotary is faster but you are still removing more paint. Why remove more clear then you need to? Forced rotation and long throw are both faster options for a DA but do the job with much less risk and much less paint removal.
If you are doing heavy cut compounding with a DA, you will still have to follow up with a finishing process. I am not talking about easy swirl removal here.
You need to remove the same amount of clear coat to make a defect disappear no matter if you use a rotary, forced DA, long throw DA or normal DA.
The new blackfire aio can remove heavy sanding marks so I'm just saying, the technology is there to save time and get good results.
I think it comes down to paint preservation. Leave as much paint on the surface as possible.
Exactly my point. So if it is needing heavy compounding and a 2 step process. A rotary first followed by a DA is the most efficient.
Yes, you are correct. But what I'm saying is because of the speed of a rotary, you will likely level the surfaces to beyond what was needed to correct it.
There's a million ways to skin a cat....
(Sorry PETA - just a cliché)
When I say there's a million ways to skin a cat, what you use depends on what you want to accomplish plus how much time you want to invest.
A few weeks ago I cut a car using a rotary and finished out with an orbital. My PRIMARY goal was to TEST out two new tools so I could write reviews. My secondary goal was to do my best work possible as that's how I roll in the Autogeek Shire as well as wanting to show the owner my appreciation for him trusting me with his old 2-door passenger car.
Here's those write-ups with pictures that never disappear :laughing:
Review: RUPES BigFoot LHR 19E Rotary Polisher by Mike Phillips at Autogeek
Review: RUPES BIGFOOT MILLE LK 900E by Mike Phillips
Here's another cat I skinned using the FLEX PE14 Rotary Polisher first followed by my buddy Frank using an orbital. The pertinent portion is in post #2 of this thread,
How to wash Ferrari Wheels and Tires
I never was able to get to a "dedicated" write-up for the process used for the paint but I did share the process in post #2
See the text in red
Ferrari finished!
And here's the wheels and tires as well as the completed detail job to this Ferrari.
The paint was machine decontaminated using Nanoskin Autoscrub Pads on Porter Cable 7424XP DA Polishers.
The paint was then machine cut using the Flex PE14 with a wool pad and Uber Compound.
Next the paint was machine polished with the FLEX 3401 with a 5" Hybrid Black Finishing Pad and Wolfgang Finishing Glaze.
After compounding and polishing the paint was machine waxed using Wolfgang Fuzion.
watermark.php
watermark.php
watermark.php
watermark.php
Here's the skinny....
I tried to cut the paint or "correct" the paint using only the orbital but it wasn't working fast enough or effective enough, meaning I was spending too much time and too much energy trying to remove the deepest swirls and scratches with the FLEX 3401. So instead of continuing down that road I simply switched over to a wool pad on a rotary and made fast work of leveling the paint.
Then Frank followed me with the FLEX 3401 and removed the hologram scratches left by the fibers of the wool pad.
Fast - Efficient - Show Car Quality
You are assuming that someone is making a mistake with a rotary but not with a DA. Let's take mistake out of the equation by saying the operator is proficient.
I am assuming the operator is proficient. I'm just not assuming the operator is perfect. I'm not saying the rotary is not a necessary tool but the rotary really shouldn't be the first thing a detailer goes to, especially on a factory paint job that someone from the dealership has already buzzcut with a rotary.
A modded 21, 5" plate, xtra cut megs mf pad, m100... Yeah, give me the wool / rotary. I don't want to see bare metal.
There are times when I do a few test spots and determine my rotary and wool is needed. For example, I might do 2 test spots with my Flex 3401 and increase the aggression with the second test. If the second test is an improvement but not yet enough it's rotary and wool time. The last time in recent memory was a black Cad Escallade swirled to high heaven. The paint was very hard. I also do not remove any more paint than is necessary to level defects. By my 3rd test spot I have a pretty good idea how deep I need to go...safely.
Yup, I could continue with my Flex and work my butt off and get similar results but time IS a factor and there are those times that a rotary and wool are needed. When I do that I have instantly gone to a 2 step job to correct.
I can't remember the last time I needed more than 2 steps to cut and polish. The equipment and abrasives are that good now. They are so good that I am doing a lot of 1 steppers. Most of my work is done with my Flex 3401...whether 1 step or 2. BUT, when faced with hard paint and needing to cut down faster I always reach for my rotary.
And yes, I know how to use both. It's just that the Flex does almost as good as my rotary especially with today's products. "Almost as good" means I need to go rotary to save time ON SOME JOBS.
Having said all that, I agree that on certain jobs I cut with my rotary and refine with my 3401.
Good discussion btw. I enjoy other's perspectives.
Imo Rupes and microfiber/wool beats rotary in terms of cutting power unless you use those 10 inch knitted woolpads. I hardly ever compound with rotary but i sometimes like to finish with it just for fun and change.
If this is your claim, then is it correct to say that the Rupes possesses the same or more risk factor as that of a rotary since it has better cutting power?
