Manilruben
- Nov 25, 2018
- 28
My third project was VW polo white with 30k done on the odo with lot of swirl and oxidation.
As per books of detailing says , pepped the car decided to go for two step and finally seal it with Sonax polymer Netshield .
First step :
Rupes Duetto polisher
Menzerna 400
Rupes Blue coarse wool Pad
I primed the pads then went to work with it after completion of first panel I noticed that the swirls were only partially removed after 2 passes so went ahead cleaned the pad. Then did the third pass but there was haze and marring.
As this was wool pad i was convinced on the haze and went ahead with the second panel. Half way down the pad snapped and there was lot of heat when I touched the pad. My speed of the machine was 4.5 only
Any help why this happed ..
Then changed new ones and completed the first step. Though I did not get the finish I was expecting. So decided to with 2nd step with Menzerna 3800plus and Rupes yellow Foam pad. Though finish is 80% I am still not understanding WHY AM I NOT GETTING 100 percent defect free after two steps
Please guide and help
The finished VW is
First step :
Menzerna 400
The finished VW is
