Jeremy1976
- Apr 13, 2015
- 978
That's good stuff! I wonder how long it's going to take to start seeing more and more micro polishers on the market.
Sent from my Pixel using Autogeekonline mobile app
I wish they offered a non-rechargeable model without the kit. Big props to their marketing team, but I can't spend that much on a bundle. I'd rather piece the polishes/compounds myself (or use what I currently have) and go without paying for the battery technology or battery replacement.
Totally agree!! I don't need the fancy bag, pads, polishes, & MF towels. That alone would knock off at least $125 I figure? I would pull the trigger then.
Indeed on the power issue. And or use Milwaukee as the platform on batteries. The deal breaker for me is the battery system. Don't get me wrong. I love me some cordless.....I have gone cord free up to the SDS hammers, KO tools, and the list goes on. The issue with the iBrid for me is simply for a weekened warrior for myself, the ROI on batteries will be nullified. Or a AC/DC like the Mirka Ceros
1. Part of the expense with the tool is the ability to have a small tool that will not lose power, that will not bog down due to inadequate power, and in such a small platform. The electrical motors took a lot of engineering to make in order to be able to meet demand and function correctly. And to run off battery for sustained time (30min) plus the added tooling to switch functions cost a bit also.
2. The price likely only makes a bit of profit margin (until many get sold), but to justify it, they had to throw in the case and extra bits to make it look worthwhile to the end user.
3. In a year or two, I would bet they start offering tools at the lesser prices without the kits for replacements for ones that wore out. They IMHO will I assume end up making a 3" that functions the same or added bits to allow for 3".
This is viewed by many in the detailing world as a game changer. One tool that will do rotary, and DA and give you the ability to change heads for orbital throw depending on what panel or crevice your working in. There are so many possibilities with this tool we haven't even begun to see what comes of it.
Many people such as Kevin Brown, Mike Phillips and the like, will start developing their own special pads, or backing plates for this tool to accomplish work they are doing with better results. ( I am already going to be using 1" MF cutting pads with this, but NOT on rotary setting) This will end up trickling down to those who just do home Paint Corrections. Those who are in the PC business will have uses for these tools, however not all will. But eventually most will end up buying one so it will be a real big seller for RUPES. I am willing to bet, this tool will outsell the Bigfoot line of large throw polishers at some point. Too many different uses. Hell I am planning on using it on a side project to brush the grout in tile in a bathroom. Beats water and power cord for sure.
Just some thoughts.
Hey Velocity -
Off topic, but the only grout I specify is epoxy grout these days. It's a ton helluva lot more work in application and cleaning off, but the tradeoff is that it's completely non porus....I once had a dinner party, red wine bottle fell....and the grout was unfazed. Look into that if it has not come across your radar. btw, just to be clear, it is truely a b1tch to use on the epoxy grout, but it pays itself off in spades.
Just some thoughts.
There are plenty. Just not with a battery option and switching from rotary to DA.
Rupes ta-50
Rupes lhr75 (arguably)
Flex PE-8
3M 28363 (arguably)
Many 2" pneumatics
And now a dremel type device with special pads
All of that is true. However, from what I can see, the price is a barrier for most people who would want to buy one, but are not generating revenue/income from the iBrid. There has been a lot of engineering time and expense built into the unit because it is cordless. If Rupes were to keep the head assembly, and make a corded unit at a significantly lower cost, they could create a complete aftermarket for the unit.
Create a unit that is corded, that can use a somewhat less efficient (= cheaper) motor, which is not an issue as it will be corded, and perhaps make the handle smaller. They could do this a couple of ways: Straight wall power, or through some sort of locking power adapter/wall wart type power. Keep the rotary and 12 mm DA head attachment options, make the 3mm DA head optional. Un-bundle the rest of the parts that are in the kit. If that is done, and they can cut to cost to below $250, they would be able to create an aftermarket like the PC did. It would make the iBrid Jr. (for want of a better name) pretty much a standard part of any detailer's toolkit.
The other part, of course is the batteries. While professional detailers would use the current cordless iBrid pretty much all of the time, so the batteries would be used, and maintained constantly. However, the non-professional detailers would be using this far less often. This will lead to batteries failing pretty quickly, and while this may be an assumption, I don't thing that replacement batteries will not be cheap. This may even be a factor for professional detailers.There are many people who buy cordless drills for example, that use them only a few times a year, and the batteries fail within a year, I think far more batteries fail due to lack of use than do because of wearing out, and it applies to all battery types, including Lithium based ones.
