Not necessarily so, someone posted that they wished they got the short neck because the long neck would not get into some areas because the neck was to long. Just wondering if I would encounter the same problem. Plus they felt that the short neck was more stable. Dunno.I don't have one...yet, but I think I'm gonna go long neck just in case I ever need it I'll have it, if you get the short neck and need the long neck you are SOL but the long neck can reach anywhere the short neck can
Sent from my Pixel using Tapatalk
I guess I can't think of a vent or Louvre that the long neck wouldn't fit in and u could o my use a shortNot necessarily so, someone posted that they wished they got the short neck because the long neck would not get into some areas because the neck was to long. Just wondering if I would encounter the same problem. Plus they felt that the short neck was more stable. Dunno.
Short for me. I had to put effort in making sure the pad is flat so that the pad would keep rotating with the DA function. I would imagine this will be slightly harder with the long neck.
Ron, I have access to both and have not found anywhere the long neck can go, that the short neck can't also go. I think Marc hit the nail on the head with his assessment of the limiting factor being "the distance from the face of the pad to the top of the head". You can't go wrong with either!
