Yes you can do it. I haven't has a chance to mess with mine but even without it when I tested it it has power.
Individuals can do as they please because they are only held accountable to themselves.
I spoke with Marco D'Inca and Andreas, (Rupes Engineers), Francesco, the Marketing & Communications Manager, (in control of the message), Gionata, the Business Development Director, Guido, the President of Rupes, Chip, the US Market Development Manager and Torben the Sales Manager for North Europe, a number of times in our booths plus a couple of closed meetings and not a single one of them suggested or recommended modifying their tools with a washer or in any other manner.
Thanks for asking the question though as it gives me the opportunity to share the official Rupes message.
Good question. No, it doesn't. The washer mod is worthless with the 75E.Does the backing plate touch the housing?
Is this mini better than a DA (like Meg's v2 DA) using 3" plate?
I'm asking this because I'm willing to sell my Meg's (here in Brazil, used, it worth ~400-500$), so I'll use the money to order a rupes mini for spots at AG.
I'll open a thread when my time arrive, but any input would be helpful now.
Kind Regards.
Does the backing plate touch the housing? An unboxing video I watched said that it doesn't. If it's not touching, a washer spacer will not accomplish anything useful as in the case of the 15 and 21.
I have found when using foam pads with the 75E, very little pressure(if any) should be used. It does not do well with sharp angles when using foam. It does good when the panel is just wide enough for the pad and flat. However, I decided to try it with Meg's 3" MF finishing discs. Figured the soft foam interface would help with contours. Holy cow, it made a HUGE difference. Thing rotated like a bat outta hell! Haven't tried the 3" MF cutting discs yet.Well thanks for all the responses. Unfortunately my fears have been confirmed that the mini's rotation cannot be improved upon. I'm used to correcting with a flex 3401 and love the option of applying a bit more pressure without loss of rotation in order to correct tougher spots without having to change pads or product. However, the mini works beautifully on motorcycles!
