dlc95
- May 18, 2013
- 6,062
- 26
Please take a close look to RED marked areas.
It is clearly seen that there was a lot of friction and heat going between backing plate and the shroud aka Anti Spin. Yes I know it is common, but not THAT much.
So we can be assured that no 'washer mod' was installed.
A lot of friction created a lot of heat, heat created expansion, softens the material. That was probably the cause of the BP failure.
Only question is, why there was so much friction between those two ? No lubrication ? Too much torque caused BP to be in very close contact with shroud ? Improper BP mounting ? Who knows... not me.. me only knows how to shine things.
Usually the shroud will wear away, but it doesn't appear ti be the case here.
