Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
RUPES Nano iBrid Short Neck - What's in the Box?
Suggested retail for this bad little boy is $700.00 in U.S. dollars. You can pre-order right now for $560.00 and save $220.00
So when you pull out your wallet and plunk down your hard earned cash what do you get from RUPES? Well let's take a look at what's inside the box or more specifically, what's inside the tidy carrying case.
Everything you need to start polishing with surgical precision is included in the kit.
Battery Charger
2 li-ION battery packs
4 each 2" coarse blue foam cutting pads
6 each 1 1/4" coarse blue foam cutting pads
One 150 ml bottle of Zephir Coarse Compound
One 150 ml Keramik Fine Cut Polish
6 each 1 1/4" yellow foam polishing pads
4 each 2" yellow foam polishing pads
One each - 2" backing plate
One piece design with threaded stud on the back
One each 1 1/4" backing plate
One each nylon scrubbing brush
One each soft bristle brush
Wrench
1 1/4" backing plate for sanding discs
10 each #2000 grit sanding discs
10 each #3000 grit sanding discs
AC-DC Adapter
BigFoot Premium Tool Case
Full RUPES documentation
Battery Charger
Wrench
AC-DC Adapter
