WRAPT C5Z06
- Nov 12, 2009
- 12,615
ALWAYS start the machine loaded against the paint. Obviously, you don't want sling, but more importantly, it keeps the oscillation and rotation balanced. I got this tip from Kevin Brown.
"Both machines employ a backing plate anti-spin "feature" that slows the rotation of the backing plate via friction; which is to slow excessive backing plate rotation in situations where the pad is not under load while the machine is running (either the pad has minimal or no contact with the polishing surface or there is very little friction between the polishing surface and buffing pad). This is done to prevent erratic interaction between the pad and paint surface and to eliminate the chance that the pad will inadvertently scour the surface."I believe this is the reason that the Rupes designers implemented the "soft start" feature so that if you accidentally power on the machine, it will not ramp up to full speed right away. Also, isn't this why they implemented the cowling on the back (that the washer mod nullifies)?
Hi Mark...ALWAYS start the machine loaded against the paint. Obviously, you don't want sling, but more importantly, it keeps the oscillation and rotation balanced. I got this tip from Kevin Brown.
Here's a tip... don't lift the pad off the paint till you've turned the polisher off and the spinning pad has slowed down...
Whoops!
Here's what happens when you lift a polisher off the paint before allowing the pad to slow down and stop spinning...
This happened at out Detailing 101 Class...
Pictures & Comments from September 18th, 2010 Saturday Detailing 101
Remember to allow the spinning of your pad to slow down before lifting the pad off the surface...
Don't lift your pad before turning off the machine!
Mark
who starts a machine off the paint? This is just common sense.ALWAYS start the machine loaded against the paint. Obviously, you don't want sling, but more importantly, it keeps the oscillation and rotation balanced. I got this tip from Kevin Brown.
I'm not talking about starting the machine 5 feet off the paint. I've started the Rupes ever so slighty off the paint because I don't like how the soft start feels, but now, that'll change. The pad needs to be in full contact on the paint.who starts a machine off the paint? This is just common sense.
Pat, the washer mod really helps! :dblthumb2:Great tip Mark. I just did the "washer mod" myself. Can't wait to give my Rupes 21 a "spin"![]()
