I can't help you on the nozzles, but it looks pretty nice, I like the non-tipping cart design. It's a little light on the "cleaning units" if you use the formula from the pressure washer site.
if i didn't already have the electric pressure washer i do, i would buy this or the black max version which is essentially the same. i believe it uses a standard quick disconnect (attached to the foam cannon) which you can buy at lowes/hd...
Thanks much. Standard quick disconnect makes replacement parts easy should issues arise.
I am actually going there tomorrow. I'll check it out more closely.
Sent from my VS840 4G using AG Online
If you buy any thing at HD and use their credit card just ask for 5% off and they will give it to you
I have the black max and it works great had to replace the gfi plug on it but other than that its been great got it for around $80 i think from some tool place that my father in law found...
Sent from my DROID RAZR using Tapatalk
