BrianMcLeod
- May 10, 2013
- 812
When sanding headlight with the PC to restore them what speed do y'all use on
500 grit
800 grit
1200 - 1500 and final
3000 grit
500 grit
800 grit
3000 grit
How do you know you've taken down of the oxidation when sanding? I tried wetsanding for the first time on some practice lights, I started out with 500 ended with 2000 then compounded and polished. After polishing it still wasn't clear so I went down to 360(lowest grit I had) and it came out better but looks like I will have to go down even lower.
Did I do anything wrong or just didn't take out enough of the oxidation in the initial sanding? I used a rotary with 4" wool pad when compounding and polishing speed 3.
Sorry for the thread hijack. I tried the same process on these headlights today, you can see the left side was pretty bad. They made a big improvement but if you look closely the drivers side is much clearer(had less oxidation originally). I didn't even have to wet-sand it just compound and polish.
Passenger side went down to 360 and in the sun you can still see a bit of yellowing and not clear like the drivers. What am I doing wrong? I'm going to go down to 220 and do cross-hatch unless im missing something.
I've actually went from 800 to 3000 with great results. I've attached some photos
Sent from my SAMSUNG-SGH-I317 using AG Online
Dry sanding in the beginning is faster. The goal is to remove a layer of plastic (the yellow). The color change and cloudiness comes from oxidation. Wet-sanding is a less aggressive approach thats why it's used in the later steps when refining your previous sanding marks.
Still wondering if one can go from 800 to 1500
And skip the 1000?
Anybody know?
