Saver Applicators--Suede or Terry?
Setec Astronomy
For those of you who use the AF Saver applicators, which do you use, the suede or the terry, and why?
Do any of you use the finger mitts? Or the blocks (velcro or not)?
I’ve tried both, thinking I would probably prefer the suede applicators but honestly I like the microfiber ones better and will reorder those.
Product slides off the suedes too easily and for whatever reason they seem a little more difficult to hold on to.
Surprisingly, the microfiber ones are my choice.
  • Like
Reactions: BLM
I use the thinsaver MF applicators for interiors and like them. haven't tried any other variations.
Only ones i use. Used to use the smaller block ones but i found these to not only cover more area but spread coating out better for me.
I've tried the thick regular and mini MF applicators. I haven't tried the suede or the fingertip ones.
As a coating applicator the mini's are my favorite. I like how I can get into much smaller areas with them, and just like how I'm able to hold them for the way I apply a coating. This might be because I used the foam block and suede swatches when I got into coatings and the mini's have the same form factor. If I was going to apply a sealant I might use the larger applicators, but will stick to mini's for the coatings.
I bought these from TRC as the Autofiber pads were out of stock on Amazon when I bought them. Assume they are very similar to the Autofiber pads.
Same here. They’ve worked out great for me.
Thin Microfiber are my favorites. The smaller Mini’s work nicely on wheels as do the finger mitts. Finger mitts also good for leather coatings.
Tried the Saver Applicator cloths w the block but immediately didn’t like them…too bulky overall. Suede was nice when trying to get a very even thin coat but not much need for those anymore.
Sent from my iPhone using Tapatalk Pro
MF for me. Holds the coating better IMO
I got into coatings when OC 2.0 was made available. It's funny how things have changed, I gave up on coatings for a while and now you kind of apply them opposite of how you used to, unless I was always doing it wrong. I mean back then I thought the object (as BudgetPlan1 alluded to) was to go super-thin and only wipe off if you got high spots, now it seems you put "a lot" on and wipe it off, so you want a different kind of applicator.
I think some of this depends on the coating. Gyeon coatings seem to go on thicker and are a bit more viscous that others. CarPro (CQ UK 2.0, 3.0, and the old Ti) coatings I've found go on much better the thinner you can apply them. You still need to buff them out to get everything level, but in my experience, you get CQUK too think and it will take forever to flash and you have to really worry about smearing.
I have learned from another member on here(eric) that you only need to apply enough coating to get a reaction on the surface, Laying on heavy just leaves you more excess coating to push around during wipeoff. Even for the one layer coatings.
Why do you guys like the thin ones? I would think the thick ones would be easier to hold on to, and they shouldn't absorb more product, because of the barrier...or do they?
Anyway, I bought the thick ones because they were on sale--I just got them, and they seem ENORMOUS (talking about the area, not the thickness). I also got some of the mini's, and they seem too small.
Thin and thick should have same foot print. Easy to hold and easier to get under spoilers, mirrors and door handles.
Just as crack said, easier to get under mirrors, spoilers and such. Easy for me to hold.
I thought the barrier was right under the mf, regaurdless of thickness. But id check their site to be sure
Yes, I'm sure the barrier is right under the MF regardless of the applicator thickness--of course what you guys are saying about the thinner applicator getting into tight spaces makes sense--I still have my head in the old-school coating days. I used to follow Anthony Orosco's advice from the original Opti-Coat days (Anthony had his own detail shop and was the founder of the Optimum Forum, you know him today as the importer of NextZen).
Opti-Coat (or for me, Opti-Coat 2.0, the retail version) used to come with a yellow foam applicator. Anthony thought this absorbed (and wasted) too much product, so he stuck the applicator into a nitrile glove, and wrapped Scott blue shop towel around it, and used that to apply the coating. So I would just use the blue towel by itself in those tight spots.
I guess maybe that makes Anthony kind of the grandfather of the suede-microfiber-wrapped-around-a-foam-block method, or even these saver applicators. As I've mentioned here before, Anthony, by his telling, is also the conceptual father of WOWA sealants. The story he tells is that he and Dr. G were demo'ing Optimum polishes at a GM plant in Texas, and went out to dinner after and Dr. G asked him what kind of new detailing products he would like to see (this was about 20 years ago) and Anthony said "I'd like a sealant that you can just wipe on and walk away, and it will last forever", so Dr. G went to work and ultimately came up with Opti-Coat, and Opti-Seal along the way.
For getting inside tight areas such as around mirrors, under door handles, along moldings, I just use a soft sponge. Standard size maybe 1/2 inch thick and roughly 4 inches x 6 inches.
After all those are very limited areas on the vehicle and the sponges are cheap, easy to get and easily cleaned out.
Make up sponge applicators are cheap and were popular for awhile
Oops...I should have specified, as coating applicators.
If your not doing this for a living, microfiber app.
If you are, suede.
The microfiber is easier to work with, but you will use a lot more product (at least I do...)
