Whitethunder46
- Oct 30, 2006
- 1,594
Scenario: Average paint condition as far as hard/soft goes.
Swirls: average amount for say a... 4 year car.
What combo would you grab first and why?
What combo should you grab first if you were going by the "textbook."
The polishes would be either Optimum line or XMT 1-4.
Edge pads (or LC pads that are similar in cut).
Would you grab for a yellow Edge pad and XMT 3 or green pad and XMT4?
Would you grab yelllow pad and OC or green edge pad and OHC?
Get the game?
I basically want to know what is going to give the results the best and be the "smarter choice?".
For instance... yellow pad and OC should get everything out, but you're almost guaranteed some micromarring from the heavy cut pad which you would have to go over with a lighter polish/light pad and really take the time to get out the marring.
OR you could use OHC and green pad BUT you may not get all the swirls out, so you would have to take the time to step up (which is somewhat of time wasted). If it did get all the swirls out, you would more than likely have hazing from the OHC which you would then go over w/ a light polish/pad but could do this step quicker than the finishing polish w/ the scenario above.
EDIT: would your choices vary depending if it was w/ the PC or a Rotary?
Get the game?
