Markymapo1
- Jun 26, 2018
- 663
Thanks for all the info n hard work. Very useful!
WGDGPS got 6 weeks in the first test. If you look in the WGDGPS column you'll see another dot at a little under 10 weeks. For products with multiple tests you'll see multiple scores. The score that looks like one week is because I just applied it so it's currently at the bottom. The marks with a triangle in the middle are in progress. You'll see them continue to move up over time until I mark them done.
Make sense?
Sure, esp since I already have it. Will try to to it when the next panel opens up. If I recall the consensus is that it's not very long lasting.Could you find a spot for Essence Plus in the future.
I like the way it works on my wheels but not sure about durability.
I used it over a 15 month gloss coat application on my car and rode through the winter with it.
I always use boosters of some sort after every wash so my results are always skewed.
Are you perhaps asking about Reload, the sealant? Reset is a car wash. I applied Reload per the instructions on the bottle. if I recall it's supposed to flash before being removed. Given I'm using such small areas I likely over-apply everything. I used Reset at 500:1 with a microfiber towel (rinsed, washed with Reset, rinsed, and dried).Hey I'm a day late dollar short, but how did you apply reset? Heavy, double wipe, wait X amount of time before applying etc
Really don't feel qualified to say what's best. I'm just some random jackass testing products.Maybe this is a dumb question. So what are we saying is the best?? Im looking for the easiest product but great durability.
