3-Categories: Waxes, Paint Sealants and Coatings
In an effort to help
standardize terms used in the detailing industry, now that
CQuartz and
Opti-Coat 2.0 are mainstream, there are three general categories in the
"Protection" category
- Waxes
- Paint Sealants
- Coatings
Waxes
Generally defined as any product that contains a natural or synthetic
waxy ingredients that are intended to protect the paint and/or add beauty to the paint. These types traditional waxes will wear off under normal wear-n-tear, repeated washings and exposure to the environment.
Paint Sealants
Generally defined as any protection product that contains man-made or synthetic ingredients that are intended to protect the paint and/or add beauty to the paint. These traditional sealants will wear off under normal wear-n-tear, repeated washings and exposure to the environment.
Coatings
Generally defined as any paint protection product that contains man-made or synthetic protection ingredients that are intended to permanently bond to the paint to both provide a barrier-coating of protection as well as create a clear, high gloss finish. The products available in this category are considered permanent coatings because like your car's paint, they cannot be removed unless you purposefully remove them or you purposefully neglect them.
Definition of permanent in the context of sealing paint
This is kind of tricky just because the nature of discussion forums is for some personality types to read super literal into each and every single word, in this case the word permanent.
In the context that we refer to coating as permanent it means that once the coating is properly applied and allowed to cure and set-up, it will not come off under normal circumstances or via normal wear-n-tear such as careful washing. So in this context, a coating is permanent in the same manner your car's paint is permanent.
The paint on your car is not going to come off unless you abrade it, chemically dissolve it or in some other mechanical means, purposefully remove it. In this same way, legitimate paint coatings are not going to come off unless you abrade it, chemically dissolve it or on some other mechanical means, purposefully remove it.
Traditional car waxes and paint sealants will wear off under normal use circumstances or via normal wear-n-tear such as careful washing. So in the context of and in comparison with traditional car waxes and paint sealants, paint coatings are permanent.
