O
opie_7afe
Guest
glass is the easy part to get overspray off of atleast you can use a normal razor blade(not carbon steel as it will scratch) if you feel comfortable you can use a razorblade but you need good technique i used one to remove straight up paint from most of a fender on my car (crappy quality paint that just chipped off easily) it did mar up the underlying un prepped factory paint but not that bad but i dunno i exhaust other options first as you can have a twitch and the blade digs into paint. or just continue wetsanding. good luck again!
