Shampooing
Colton205
Today I was shampooing a Chevy Malibu with those colth seats!! It was in bad shape!! I use mytee lite 2 and drill brush with formula 50 Apc and lemon grass extract it both Zep products!! I caught hell!! Is it possible to get really bad interior spotless without taking out everything??
How many passes did you do ? sometimes if the seats are really bad you need to spray soap, use the drill brush, extract, and repeat!
Also another thing would be to use different cleaners on the spot if it's not coming out, it's a good idea to have more than one chemical in your arsenal because some stains are just not affected enough by a certain chemical, what I use is an APC first then if that doesn't work spray some folex, and again if it doesn't work just repeat the steps, once with APC and once with folex until it comes out. (spray > agitate with drill > extract are the steps you need to repeat)
BTW Folex is the #1 spot remover I know. You should invest in some of that ASAP. You can find it at your local home depot, with the cleaning supplies they have the large size but if you want the gallon size (more economical) that'll be located in the carpet cleaning section.
