Shelf life of in unopened Wolfgang coating
waterman
Hello,
I just purchased the Wolfgang ceramic coating kit but won't be able to apply it until the spring. I put on a sealant Saturday and found out on Sunday a neighbor down the street has a garage that I could have used to store my truck! Anyways, I was wondering if the coating has any type of shelf life before it is opened and after. Once I use it in the spring how long will tje
remaing coating be good for if stored inside?
Thank you
Purge the air out of the tube and I think you should be good pretty much indefinitely. Also make sure you don't get any crusted product in the threads that will keep you from screwing the black cap down all the way, if it isn't sealed tight you'll get moisture in there which will start the cure process.
