To answer your question you can certainly get rid of all of it if that is what you are trying to acomplish. As some have stated if it's a daily driver or a pickup truck that you haul gravel in or a showcar you may have different goals. I am curious why you used a white pad after you had used a black pad. Also I would suggest trying Menzerna 85RD as a finishing polish after the 205. Maybe use 205 with a white pad and then Menzerna with a grey pad and then your sealant with a blue or red pad. You can experiment a bit with the Menz 85RD and the white and grey pads.
After I use my more aggressive polish, if I'm going for a perfect finish I go with my white flat pad using 85RD and then I come back and use the grey flat pad with 85RD. Using the Flex 3401 I run the grey pad with pressure for about 4 passes and then start easing up on the last 4 passes. With the Menz' polishes I spread on 3-4. During correction and finishing I run my Flex on speed 6 about 95% of the time. I think on the megs (at least the 205) the recomended speed is lower but I don't have experience with megs yet.
fist off. i rather not buy any products that i really dont need that i already have a similar product of. that would be a waist of my money.
2nd, i am willing to settle with mico marring, its not a garage kept car its a daily driver
3rd. i used the white buffing pad last because it has light cutting power and is labeled to be good for wax cleaners , the opti-poli seal is pad dependent and i wanted light cutting power with it. maybe my idea was wrong and i went the wrong way about it but if something is labeled for a wax/cleaner i thought it was good enough to be in the final step or a 3 in one applicator like poli-seal or poor boys polish and seal.
in that case i guess i should have used the green pad? idk. i dont really understand the green pad to much i just know its pretty versatile....
but like i said. im not about to order another product and wait for it to be shipped to me. i do however have a local supplier for optimum products and adams products. but as far as that goes i'm done buying detail stuff, until i run out of what i have.
lastly. some paints are harder, some are softer, some paints are thin and some have plenty of clear. after market and stock paint jobs very. and last thing i want is to try and try and try to cut threw all the swirls and actually burn the paint right off...
i think im perfectly happy with 90% of all swirls gone, all deep scratches 100% gone, and only micro-marring remaining.
though i will walk away with the advice to do a 2nd or 3rd pass with the 105, i did that only on deep scratches... and i also wont use the white pad in 3rd step. though i dont really understand why i shouldnt, and why it would add to the problem.. it fricken says wax/cleaners right on the description... i would assume its safe for final application/polishing.
