Should I wait ???
Camryguy
Hi All,
Not sure what to do so here goes.
I applied the Klasse twins and Pinnacle Souveran Carnauba to the Camry about 2 mnths ago. I will have a AG order by Friday containing Collinite 845 and Pinnacle Paintwork cleansing lotion just to have it.
My question is with winter approaching, and a somewhat nice weekend on tap should I use the cleansing lotion and apply the Collinite for winter or just wax again using the Souveran Carnauba?
If I use the Collinite, how many applications to see me thru till spring.
The car is garaged every day.
Thanks in advance as usual.
after 2 months, the Souveran is probably gone or close to it. That isn't really a winter wax so I would just wash the car with a regular car soap and apply a coat of 845.
If you didn't want to do anything that would probably be ok too. The klasse twins will take you through winter without any problem. Maybe dilute some ksg 3:1 with distilled and use it as a spray sealant after washing the car this weekend to boost/layer the ksg that's already on there...
If you use the paintwork cleanser, you will be starting from scratch as it will remove the twins...
I agree with embolism. Souveran doesn't last long so its probably at the end of it's life. But the Klasse is still going strong for sure. You could probably get close to a year of protection with that since your car is always garaged. I would wash then apply Collinite 845. That protection should be bullet proof. For the winter I use a spray wax or sealant when I wash my car with ONR to help everything survive until the spring. In the spring use the Paintwork Cleanser and start experimenting with new LSP's :)
Same page as all above. Since you have the Klasse Twin base I'd just layer with the Collinite and strip in the Spring.
Thanks for all the replies, will follow the above suggestions.
Now just waiting for my AG order to arrive and hope the weather forecast does'nt change for the weekend. Mid 50's for November in Ohio. I'll take it.
Thanks again all.
