Silica Spray Showdown: McKee's v. Gyeon v. CarPro
Which product provided the best beading throughout the testing period?
  • Product A
    Votes: 11 31.4%
  • Product B
    Votes: 10 28.6%
  • Product C
    Votes: 6 17.1%
  • They were all roughly equivalent
    Votes: 8 22.9%
  • Total voters
    35
kevincwelch
Greetings, Detailers!
Like many of you, I am a big fan of easy-to-apply spray coatings such as Wet Coat and HydrO2. Now that McKee's 37 has a ready-to-use silica spray coating, we certainly have some solid options when it comes to selecting a silica spray.
Of course, there is that all important question: Which one is the best?
This seemingly simple question potentially has quite a number of valid qualifiers. Does "best" mean gloss? Does "best" mean hydrophobicity? Does "best" mean durability? Does "best" mean "bang for buck?" All great follow-up questions. A couple of those may be difficult to answer, but for me, silica and titania offer protection to my clear coat, and I want to know which one(s) repel water the best and do so for the longest time. Cost is an important issue, but it can be deceptive. One product may be significantly more expensive than another for the same volume, but the more expensive one may stretch further, and that's value, which is separate from cost.
So, I set out to do a test of three ready-to-use silica spray products and to do my best -- with your help -- to determine the level of gloss, hydrophobicity and durability of these three silica sprays.
I decided to use straight-from-the retailer versions of the three ready-to-use silica sprays as opposed to ones that I have to dilute on the bench -- avoiding any potential issues with my water quality or failure to measure properly.
The Contenders
1. CarPro HydrO2 Lite
2. Gyeon Q2M Wet Coat
3. McKee's 37 Hydro Blue SiO2 coating spray
Costs
All costs are based on the regular (not sale) Autogeek regular pricing.
McKee's 37 Hydro Blue (16 oz): $17.99 ($1.12/oz)
CarPro HydO2 Lite (1 Liter, 33.8 oz): $24.99 ($0.73/oz)
Wet Coat (500 mL, 16.9 oz): $17.99 ($1.06/oz)
Wet Coat (4000 mL, 135.3 oz): $84.99 ($0.63/oz)
In terms of cost, Wet Coat is clearly the least expensive when bought in bulk. However, many of us may not be in the market for 4 liters of a product if our rate of application doesn't necessitate such bulk purchasing. Eliminating this 4 liter option, the 1 liter CarPro HydrO2 Lite is the next best option in terms of price, followed by Gyeon Wet Coat and then by McKee's 37 (the most expensive per oz). Obviously, the differences in price between McKee's 37 16oz and Wet Coat 500 mL are negligible.
Cost isn't everything, of course. If you have to use more Wet Coat than McKee's to get the same results, for example, then McKee's clearly is more cost effective. Many permutations of this sort of thing go into cost assessment. However, on a per-ounce basis, it goes:
Wet Coat 4L < HydrO2 Lite < Wet Coat 16oz < McKee's 37 16 oz
(You can buy a 5L container of HydrO2 Lite elsewhere for $99.99. This turns out to be 169.1 oz and a cost of $0.59/oz - the best cost/oz for any of the products.)
Soon Gyeon Wet Coat Essence will be out, and a 250mL (8.4 oz) bottle of this will cost in the neighborhood of $50.00. Instructions state that it can be diluted from 1:5 to 1:15. If that's the case, Gyeon Wet Coat Essence will cost anywhere from $1.19/oz (of diluted spray) to $0.39/oz. Good value.
My disclosures/Avoidance of Bias
I like Gyeon. Although I have CarPro products, I usually don't reach for them (got streaking from Reload, hated PERL and have had +/- streaking with HydrO2 in the past). I don't have many McKee's products because it's a relatively new line of products, and Hydro Blue is completely new, so there's little available information out there about its outcomes, although Joe and Ron have some nice reviews out there. So, I wanted to do a test that avoided bias on my part and bias on anyone else's part.
Study Parameters/Methods
I took three identical spray bottles and filled each with 50 mL of each product, which was measured and transfered straight from the source bottle. On each bottle, the spray nozzle was turned all the way so as to maximize the atomization of the product. Each bottle was primed so that the piping and sprayer were filled with product so as to avoid unpredictable variability in the spray pattern and volume. Each bottle was marked with what product was present. You might ask why I needed to mark the bottles if they are all three different colors. Good question. This test is going to involve a longevity test, and I wasn't sure if after a few months (before the unveiling!) whether Hydro Blue and HydrO2 Lite might start looking a little alike due to color fading, oxidation, etc.
Each bottle was then completely covered such that I was unable to tell what product was in the bottle. The bottles were then randomized by my wife (I was not present when she rearranged them), and then she marked each bottle with a simple code: "A," "B" and "C."
The hood of my wife's 2015 Toyota Highlander was cleaned using a heavy saturation of Kenotek and then decontaminated using a fine grade Nanoskin sponge. It was then corrected with HD Adapt using a Rupes Mark I 15 with a yellow Rupes pad. This was done to get rid of the previous LSP. I then polished the hood using Sonax Perfect Finish using a Rupes white pad. The panel was then prepped using Gtechniq Panel Wipe.
Just checking them temps...
The following video shows that there is (hopefully) no LSP left on the hood and the effect of water after being sprayed on the hood. I did this because I have seen some reviews of these products that have been done on cars already protected with something. See Joe's post on applying a silica spray coating product. There's an excellent video.
Don't adjust your dial! None of my videos has sound -- I edited the sound out.
Highlander Hood
The hood of my wife's Highlander was divided into three sections using the technique described previously by Marc08EX in his test of Wet Coat and HydrO2 Lite. See his review here. I used larger sheets of plastic and double taped the hood to avoid overspray. The tape was applied to both the top and under surface of the plastic.
Arbitrarily, I made the following assignments.
Passenger's side: Product A
Middle: Product B
Driver's side: Product C
Reminder: I don't know what product I am spraying on each section at this point. This is a potential problem since the three products may have different instructions for applications. After reading the instructions on AG/McKee's, Gyeon, and CarPro, I confirmed that the instructions for application are generally the same for all three products - hence their ease of use.
HydrO2 Lite
3. Surface must be well cleaned from soap residue and left wet with water.
4. Spray fine mist of HydrO2 on no more than 1/4 of vehicle before rinsing. Very little is needed and no overlap is needed.
5. From time you start spraying a section to rinsing off should be approximately 30 seconds or less.
6. Immediately rinse well with strong water nozzle.
McKee’s 37 Hydro Blue Sio2 coating works best on a vehicle that is well maintained (recently clayed and polished). The smoother the surface, the longer McKee’s 37 Hydro Blue will last.
Working one panel at a time, on a vehicle that has just been washed and rinsed (but NOT dried), spray McKee’s 37 Hydro Blue directly onto the panel and immediately rinse off using a strong jet of water. Continue this process around the entirety of the vehicle.
Gyeon Q2M Wet Coat
GYEON WetCoat is unique in that it is safe to use on almost every exterior surface of your vehicle. Use it on paintwork, plastic, metal trim, rims, and even glass! A few quick sprays followed by a rinse are all it takes to create a super shiny, hydrophobic surface on your vehicle!
Application
Making sure to avoid overspray and have the plastic sheets adequately cover other treated surfaces, the exposed sections of the hood were each sprayed with water to wet the surface and then sprayed with the test product. Each section was sprayed without significant overlap, and a total of 7 actuations (what I determined to get full coverage) were performed on each section. Immediately following the application, the section was blasted with water to activate the product. Each of the three sections was then dried using its own towel to avoid any possibility of cross-contamination.
Here are the three videos of each application.
Product A/Panel A
Product B/Panel B
Product C/Panel C
The tape and plastic was removed. A cure period of 6 hours was utilized before water testing. I don't see any indication on their respective websites that this is necessary, but cure periods for silica and titania products are often recommended.
Water Testing
The first test of beading is done with water sprayed on each section. A Home Depot basic $0.99 sprayer was used with distilled water. Here are representative pictures of each section. Your opinions would be highly valued.
Product A/Panel A
Product B/Panel B
Product C/Panel C
Opinion: I believe that the beading quality ranks Products A > Product C > Product B, but not by much. Although this is subjective, they all have nicely formed round beads of variable sizes without any section showing those amorphous or poorly organized beads. Again, in my opinion, I was slightly more impressed by the beads of all sizes shown by Product A/Panel A compared to the other two. Regardless, they all form nice beads.
I also performed a test to see which did the best in terms of water sheeting. You can see where the hood was masked. The video demonstrates the results. Again, your opinions would be highly valued.
After
Opinion: I felt that the sheeting of water was much more organized in all three sections/panels than when compared to before any treatment. Sheeting again is a subjective thing. Some equate speed of sheeting with effectiveness, any I can see that, but angles of panels all vary and gravity affects speed. In this case, Panels A and Panels C have a little advantage in having more acute angles than Panel B since they curve down to the side, so I think that A and C sheet a little faster. Regardless, after 1 minute, the sheeting is nearly complete in all panels.
Gloss
This is going to be completely subjective and may have no real winner with the limits of my testing. I don't have a $3000 gloss meter, so we're just gonna have to settle for subjective opinions here. Here is the hood from three different angles under the reflection of LEDs.
Opinion: I think they all look the same. Hard to say on a light metallic blue car.
Longevity
Here are the durability claims of each of the three products:
1. McKee's 37 Hydro Blue: "3 months or more." (Source=McKee's 37 website)
2. CarPro HydrO2 Lite: "3 months or more" (Source=CarPro website)
3. Gyeon Wet Coat: "up to 12 weeks" (Source=Gyeon Quartz website)
Today marks T=0. At T=2 weeks, T=4 weeks, T=8 weeks and T=12 weeks, I will be performing a water test of the hood. The car is going to be maintained by me alone. I usually let me wife go to the touchless car wash periodically, but I've asked her not to do this over the test period since they often use harsh chemicals and lay down sealants in the rinse, and both of these may affect the products tested and I can't control the car wash concentrations, etc. Instead, the car is going to be cleaned with McKee's 37 N-914 using the rinseless wash dilution and dried using a towel. McKee's N-914 was chosen since this is a wash that is reported to leave nothing behind on the surface that affects the underlying LSP. After the RW, each section will then be sprayed to assess beading properties and hosed to assess sheeting capability. Pictures and videos will be taken.
At 3 months (or sooner), if all three products no longer demonstrate any protection (beading, sheeting) the products will be unveiled and final conclusions will be drawn. However, if any of the products continues to demonstrate protection beyond this time frame, updates will be given until all three products have "failed." Only then will the unveiling occur.
Summary
There are now a few ready-to-use silica sprays on AG that can be used to protect your paint surfaces. Although durability is not stated to exceed some of the higher quality waxes, sealants and dedicated coatings, silica sprays are a contender in this market since they lay down protection, are relatively inexpensive per oz, easily applied and leave a great look. There will always be matters of subjectivity and nuances related to paint/clear coat and with the application itself. The question of durability always seems to be a very important one to answer, and durability is affected by many factors. I feel this is a legitimate test of the three products on a daily driver (as opposed to a garage queen) since most vehicles we detail are in fact daily drivers. Since the masking technique has been proven to adequately avoid overspray (see Marc08EX's post), and both you and I have been blinded to the product applications, this test will help avoid any preconceived opinions that I or you have about the individual products and hopefully answer that durability test.
As Supreme Leader Snoke says: "We shall see. We shall see."
NICE. Big test of the current 3 spray coatings. I currently have my eye on the Mckees.
my prediction though is, there will not be a noticeable difference between the three
Quick question, how does the laser thermometer help you tell if there is wax there?
or better yet what is the thermometer for?
Just making sure what the temp was... Not to hot... Not to cold.
This test is perfectly designed. Well done. I can't wait for the updates.
Excellent test, very through and thought out. I, like everyone else, am excited to see the results.
I will say when I started reading your post I laughed to myself. I just completed a 25 page paper for a grad course on qualitative, quantitative, mixed methods, and action research. I told my wife I do not want to hear/read about any types of research designs for a long time.
So to relax I check on Autogeek, and as I read your post I can't help but to curse you for making me think about the very topic I swore to avoid.
In all seriousness, that you for taking all of that time to put that post together!
Excellent idea.
Not to add to your efforts, maybe keep a small diary of the weather (rain,snow,salt ...) that the vehicle sees during the test.
If there is a difference, it could be due to some environmental factor that a duplicate test elsewhere (different season, temperature ...) would not experience.
I look forward to your results.
AJ
Excellent test, and well thought out and executed. Anxiously awaiting the results...
ScottH
Very cool. Definitely will subscribe to see your findings. I just received my McKee's hydro blue and used it on one of my truck wheels in the sun and it performed great. Thank you for taking the time to do all of this.
Wow, cool test Kevin... I will watch with interest.
I've only used these products for wheels and not on paint but will still be interested in your findings.
Very well thought out and executed. Great job!
LOL!
Sorry, my friend. :)
I know how you feel - but hopefully this was one of those processes that made you smile rather than frown!
Stay tuned.....
Excellent idea.
AJ
Good suggestion.
I will monitor the temps and salt conditions - still snowy out there.
Thanks!
Amazing review, test and write up Kevin!!! Can't wait to see the results.
I was planning to compare hydro2 and the McKee's Hydro blue but I don't see the point of doing that now lol!!!
Thanks also for the reference to my review. :)
Thanks, Marc!
I would still do it, Marc, if you have the notion. The more information, the better! (And I have to give props to the guy who provided the basis for this test!)
Sheeting isn't very good for any of these, IMO.
I felt the same way when I compared it to the sheeting of my car coated with Mohs. I will say this about the sheeting: even though it was slow, it was complete and better then before treatment. Isn't that what truly matters? Protection?
