Is it ok to top Duragloss 105 or 111 with a pure carnauba wax?
Sent from my SM-G920V using Tapatalk
Yeah I think it should work. 105 is pretty versatile and will accept anything on top.
I use it as a base layer polish for applying a sealant.
Isn't 105 considered a sealant?
Yeah it supposedly is but I use it as a base layer as minor correcting/cleansing polish. Use that or the DG101 which is also a great base layer.
You actually get correction from 105 ?
If it's a sealant, why top it with a sealant? I can see topping it with a wax.
Works well for my needs and many others. Try it..... before you knock it.
Did you see the question mark?? Been using 105/111 and Klasse Twins before you even knew what it was.
Thanks for proving my point.
So you've been using 105/111 and the Klasse Twins without knowing what they do?
And to answer your question...I'll let you decide that for yourself
What buffer do you have?
