Smudge
Jose1959
I just got thru about 2 hours ago applying the cure on a real dark blue truck. Now it's smudged all over. Just keep rubbing or did I screw up?
Wow no replies. I called another company and got some insight on my issue . Thanks anyway.
Streaking is often caused by using too much product. Some dilute cure 1:1 with water to limit streaking as well.
Jose, as committed as I am to contributing to the forum there will likely be times when an immediate response is not possible. If you have a formal question or concern you are more than welcome to write a formal email or call in to speak to me directly. The forum is not going to be the best place for pressing issues.
Streaking, with any product is a direct sign over over use. The surface on which you are applying the product can only absorb so much material. Once it has reached its limit you will see streaks. I always like to have a secondary removal towel available when applying Q2 Cure so I can easily and immediately go over the area to which I just applied it and pick up any excess material.
I tried calling and I don't think a windex type product is the answer. I really don't think I over applied. It was probably my negligence to wipe it off completely although I did double wipe each section. The problem didn't seem to appear till I applied the cure. It appears like a oily sheen , my towels were new. My concern is removing the smudges which what I'm being told should come out with a polish. Could the prep product work?
Did you wash your new mf towels before first use? Most of them are treated with some kind of anti mold product and need to be washed before used. I would do a wash of the car and see what happens if the oily smudges remains. If possible use something like Gyeon Bathe or carpro reset that leaves nothing behind. And if you have McKees 37 N-914 on hands do a rinseless wash with and if the smudges is still there do a wipe down with N-914 at panel wipe strength. If you have a prewash product or a degreaser to use before washing it's a good thing to use before washing. And after the wash if smudges remains a wipe down with Gyeon Prep can solve the smudges.
What is your base protection to your paint?
When you are doing the next Cure application think that a big panel like roof or hood only needs 2-3 sprays. I like to when first starting on say the roof to prime the mf towel with one spray and then one more to the mf towel. Spread the product to half the roof and directly follow with another buff off with a second mf towel. Then spray one time again in the application mf towel and spread to the other half of the roof and buff off. Move on to the hood and do the same there. And to the other panels one spray is only needed to get coverage since the mf towel becomes saturated with product. If you want to spray direct to the panels I would do as Guz says and dilute it 1:1 with destilled water.
Are you applying Cure directly to the paint or spraying on to a Microfiber towel and then applying? I always apply a few sprays to a microfiber towel and then work in to the paint.
then applying?
"GYEON Q2M Cure should be used on a
clean, dry surface outside of direct sunlight.
Spray it directly onto the surface and spread
an even layer using a Gold Plush Jr. Microfiber
towel.
Flip the towel and buff the surface to a shine."
Source: GYEON Q2M Cure - 400 ml
Another reason why, IMO, it's utterly important
to have product description pages that contain:
"The Rest of the Story" (~Paul Harvey)
towel.
Thanks Bob. The procedure mentioned in the product description will absolutely work. But if someone isn't having luck with that method, should I not provide an alternate? You can absolutely spray Cure directly on to paint and work it in. If someone is seeing streaks it is 9/10 because of too much product used or Cure used too often. So spraying on to a towel first and then applying will help. There is no one single way to use any product. There are many variables involved as well as personal preference. My personal preference is to spray on to a towel first and then apply.
Ok. I didn't wash the micro fibers. I really don't think I overapplied but I guess it's possible . My plan is wash try the prep if that doesn't help. Polish it. My main concern is it setting in until I can get back to it. Thanks for all replys .
The mf towels when they are not washed first often is not so absorbant. That with the combo of over applying leads to streaking. There is sio2 in gyeon cure as I understand it and could couse high spots. But there are so little of it in it so don't think it's high spots that would need to be polished off. But maybe the gyeon rep could recommend what to use to clean it up.
One thing I know sio2 are sensetive to is high alkaline products. So if you have meguiars super degreaser d108 would take care of it. Do 1 panel at the time and spray it on diluted 1:4. Spray only on the clearcoat and work your way from top to bottom. Let it dwell for 45-60 seconds and rinse thoroughly it of with a PW or a strong water pressure from the hose. Or use another APC diluted with a ph level above 12. Do a little test spot to see if it works first to an area where the streaking is the worst. Do a wash directly after the APC treatment but it's not unsafe to use as long as you don't let it dry and rinsed of well.
Heck, I'd just wash the car first and see if it goes away. I ran into same kinda thing after doing a black car with Prime and then dropping some Cure on it. Gyeon Prep took care of it if immediate resolution is desired.
I could streak distilled water coming outta a spray bottle...its a special talent I have.
Sounds like me!
Hey Guys. Worst case scenario, the streaks or high spots from Cure can be removed with a very fine polish like GYEON Primer, which will leave a layer of SiO2 behind and not overly affect the coating underneath. It really depends on how heavy the streaks are. I have seen a simple wipe down with hot water remove them if caught quickly. Prep may also work, or a good wash like mentioned above. Cure does contain SiO2 so streaks or high spots can be a pain. They are not permanent, but certainly not pleasant to look at on a dark blue truck. So a few ways to fix it:
- soak a microfiber in hot water and wipe
- wipe with Prep
- use a fine polish to remove (this will definitely do it but the most labor intensive)
- if it is an isolated area, which it doesn't sound like this is, you can take a bit of the coating installed underneath and work it in to the streaked area and try and get the solvent carrier of the coating to break up the streaks and help remove but I wouldn't try this method over a large area. But it is nice for a small missed spot in a corner or something similar.
Hope this helps! And sorry for the rough go of Cure!
Rest of the story. I washed area twice, tried the prep . Still there swirl remover, ultimate polish, Meguires scratch 2.0 finnaly started to make it disappear. But it started streaking like a smear. So I did the whole panel probably removed all the product. I then just put 2 coats of Brazilian Carnuba wax. Looks Great. I'm not trashing the product as it probably something I failed to do . I pretty sure I didn't over apply. Just giving the story a happy ending and hopefully helping someone else. I did create a side by side comparison test for the two products . We will see how they hold up. Thanks for all the helpful replies.
