TurboScooter
- Oct 29, 2012
- 22
So set the record straight.
It is optimum's reputation on the line.
I don't see why it should be OPT's reputation that is on the line when any random person can go on a forum and spout off misinformation as fact.
People should take the source of the information into consideration and also do their own due diligence.
Especially regarding the coating thickness claims (1-2 microns) vs. Product used per panel (a few drops)
Can you please cite your source for the claims of coating thickness? As far as I know, the film build thickness sourced back to OPT is from CEE DOG's review.
And while the claim of "prime the pad and then only a few drops are needed on subsequent panels" is in the product directions, I have not seen Dr. G. or an OPT representative claim that if you follow those directions you get a film build of 2 microns.
In CEE DOG's review, the Q&A section stated that if you were to use the entire contents of a syringe you would end up with that thickness, obviously depending on the size of the car's painted surface area. CEE DOG asks about OC 2.0 in the question, but Dr. G.'s reply simply says Opti-Coat. There is room for possible miscommunication and interpretation there between the question and the answer.
I guess a more specific question could be asked, like "for a 2 micron film build, how many square feet will 10mL of Opti Coat cover?" Now that OC 2.0 is discontinued, perhaps more consumers would be interested in a question along those lines being asked of Opti Gloss.
Regardless of film thickness concerns, Chris Thomas has actually said, and I recall reading this more than once, that the goal of applying the coating is not thickness, but full coverage.
Wow, I'm not sure that information deserves a "Yikes!" response? I'll try and explain:
The solvent change was made to the pro version prior to releasing to the consumer version. The the difference to the resin was a minor tweak that prolonged the hardening to allow for a longer work time...same resin, slightly modified...but produces the same longevity and functionality while easier to use. Yes, Otpi Guard is more concenrated, but as the solvents flash away and the coating starts the process of dehydrating/hardening you will be left with a nice, even coating with either product.
The goal with either product is full coverage...not thickness.
This whole layering thing may be a product of the Zaino line which required multiple layers to achieve a certain look with extended durability. Layering is necessary for degenerative products that "wear off" with exposure to chemicals and environments, but it is simply not necessary with our coating. Whether the coating is 1 micron, 2 microns, etc. doesn't matter because it will not wear away. The same protection will be there years later. It is really not relevant which version you use or how thick it is applied from a performance POV. I'm sure there are companies that would deliberately continue to manufacturer in order to have you buy more product...and I'll be happy to sell you enough OC to layer as much as you like, but you'd be better off to save that money for gas and just apply a single coat.
This user has also said Dr. G. told him that thickness doesn't matter, as long as the surface is fully covered.
Hey Art,
I am far from an Opti coat guru, but I've done 6 vehicles now (hobby, not pro). I'd stick with a few ounces of APC in the wash bucket and don't use a wash and gloss shampoo. IPA at 15% and right on to it. You will feel it start to drag when you need to add a few drops. USE GOOD LIGHT!
This stuff is actually hard to screw up. My first vehicle took so little product that I panicked and called Optimum. Dr. G called me back and said it was fine because thicker serves no useful purpose. As long as it covered, there is no benefit with a thick coat. I've never had a high spot and I suspect you'd have to put it on pretty thick to get one. After it flashes, a light dust with the micro fiber (new) and on to the next panel. It doesn't fully harden for up to 40 days but you can wash it in 7 days. I'm saving that factoid for Jeopardy if I ever get on there. "Alex, I'll take obscure detailing facts for $100".
I would try to keep it dry as long as possible before the 7 day wash but you should be fine driving the next day. I've heard of people driving in the rain within the first day with no adverse effects but I'm easily frightened of failure so I never did that.
You're going to love this stuff.
