Soap in a Foam Gun
kevin39208
I'm sure I've read this before, but I can't seem to find it now. I just purchased a foam gun and have been debating on the soap to use and how to use it. I have Meguiar's Gold Class soap, but was thinking of getting Meguiar's D111 Shampoo. How much soap do I put in the quart container of the foam gun? Feed back please
Meg's gold class foams up real nice. That's what I was using before switching to CG honeydew. I diluted Meg's at 4 oz per quart IIRC.
Ooooo, good to hear that, I have a ton left and was hoping it did at least as good as the free sample of the DP extreeme suds I got with the gun.
You will be back to DP Extreme Foam Formula.
That will suit me just fine too! LOL. If it is what works best, when I have to buy something I will go with what works best for me. Thanks for the input.:xyxthumbs:
Fill canister with water first, then add soap, otherwise you'll never get the right ratio as the foam takes over !!
Poorboys, Griots, Optimum, and Duragloss also work well in foam gun.
DP Extreme Foam FTW. Haven't tried anything else. Don't really care to. Just got a fresh bottle of it in today.
I agree DP extreme foam, foams a LOT and is a high qaulity product. it is designed to foam.
Also if your looking for value, the only other one I would ever use is Meguiars Hyper Wash. You can use it for foam and a normal wash. It foams a lot to.
Dont buy that cheap CG stuff. It leaves heavy residue on the surface and is low qaulity.
i have tried many.
dp xtreem foam
cg honey dew foam
cg maxi suds 2
dodo born to be mild
dp is at the top. once that is done, i have a gal of megs hyper wash. (heard good things about this one)
And I must say the DP has a faint but still plesant smell of mint to it. Lotsa others have a much heavier smell to them which leads me to believe that they put too much "filler" in their products.
Chemical Guys soaps are the best IMHO. Tried DP, it was OK. CG are better and cheaper.
Dissn CG is bound to cause some comments. I like their shampoo in a foam canon. Seems to work very well.
