Solution finish question
Rrthomas78
I will be using this for the first time this weekend and I have been using hydro blue as my lsp....will these two play well together or should I skip the blue this time? Thanks for any help
Sent from my Z982 using Autogeekonline mobile app
Make sure and follow the directions. I've read of a couple of cases of it spontaneously combusting when people wad up the rags used and leave them.
Like applying any dressing..be sure that the surface is clean and dry. Any good APC will probably remove the Hydro. That being said, don't use Hydro before applying SF and do a final wipe with IPA before SF. Once Solution Finish has cured, using Hydro should be ok.
Yes. As stated above use an APC to clean the trim prior to applying Solution Finish. GREAT STUFF!! I have used Hydro blue after and it worked just fine over it once it cured.
Sent from my XT1650 using Autogeekonline mobile app
