Some advice on a compound and some stain removal please!!!!
pricha00
My 06 Rav4 is black and shows every scratch and swirl like a champ. I ordered Optimum compound and polish along with some pads when my UDM was ordered last year. Found upon using those products that they are definetely designed for a rotary. They refuse to dust and breakdown no matter how little I use or seemingly how long I try and buff the product. Learned that lesson and obtained XMT intermediate swirl remover and their #1 polish. Way better results with the orbital polisher with these. However, even with the yellow CCS pad the swirl remover won't touch the scratches. What product should I try on this? Pinnacle would be preferred. Is my yellow pad aggressive enough? Second question. Neighbour borrowed his friends truck and got white lithium grease on the passenger seat. Green fabric with what shows up now as like one of those oil stains like on the bottom of a pizza box. No colour change involved it just looks like its permanently wet in those two little spots. Any hints on removal of these spots?
Thanks, Pat.
No luck with OC? That's too bad... I was thinking about trying it soon with my UDM.
What was the sign that it was not breaking down properly? Most people here say that it doesn't dust. So what are your other indicators?
I've used XMT3 with similar results as you. It's great on swirls, even bad ones, but doesn't touch scratches, so I took the plunge and tried XMT4. Love it. Took multiple passes with a LC orange pad, but I was pleased in the end. Mind you it won't take out anything you can catch a nail on, that's too much to ask, but it smoothed out some 2000 grit wetsand marks pretty well. It was also much less scary than I thought it would be. I thought it was going to rip my paint off or something. It actually finishes down nice and doesn't *seem* to remove a lot of paint. It was also nicer to work with than XMT3 in terms of work time and dusting.
Good luck with the green fabric.
I would have to say the lack of dusting and no real hazing in a reasonable amount of time to be the reasons I would say it isn't breaking down like the XMT line. I will have to try the #4 I guess.
Thanks, Pat.
yellow LC pads are most abrasive, I use orange at maximum. Sounds like Menzerna SIP would have been a better polishing choice.
Folex and Wolfgang Spot Remover are nice interior cleaners.
I just spent over a hour on one scratch. I used intesive polish with a ccs white pad (thats the most aggresive i have) and it is still not completely gone. The thing that is makes me more mad is that I bought my suburban a week ago!:buffing: Should I order powergloss? Other recommendations?
Wetsanding + SIP on orbital ?
Only if you know what you are doing. But SIP + Orbital will remove the wetsanding marks.
i have never used an orbital to remove wet sanding marks only to apply wax seems to me that it will take a very long time using an orbital to remove any wet sanding marks also I have not tried sip is that a menzerna polish?
