sonax polymer net shield application ?
poweraid
I understand this can be used as a topper for coatings.
how long would oc2.0 specifically or for that matter any coating , need to cure or be left alone before one is to apply the sonax ?
any idea how many average applications can net out of the aerosol can ?
I have done 4 cars and still have plenty left. Sonax is a stand alone coating and remember when applying Sonax do a 2x2 and wipe of right away. It's best to use a foam applicator when applying.
yes I read up what I could on the application method . have u applied this as a topper to a coating or only as stand alone ? I'm pretty sure I've read somewhere that this was a good topper for coatings . should I wait say 30days at least before applying over oc2.0 ?
You can use as a topper but it works better as a stand alone sealant. I have never used as a topper coat after oc2.0.
I have used it on oc2 after a year so that doesn't help... but it lasts a lot longer on oc2 than any other stuff I tried on it and leaves a great shine and slickness
how long would oc2.0 specifically...
FWIW:
Please keep in mind that it is said that Optimum's 'Coatings' takes weeks...even months...
to completely cure and reach the full level of their characteristics.
After that:
Other LSP's, (applied atop of Optimum's 'Coatings'), are usually faced
with being compromised in some form or fashion.
I think we covered application here...
1987 Corvette Show Car Makeover - SONAX Showcase
De-tape and Seal with SONAX Polymer Net Shield
After we removed all the masking tape and cover-up towels and wheel maskers we re-wiped any residues off the paint and then applied the SONAX Polymer Net Shield
Apply by hand
Directions on the label say to apply by hand to a small section, work in and the remove before moving onto the next section.
Careful wiping
While some of the guys were applying the Polymer Net Shield, others were carefully wiping off the excess using the very soft, rolled edge green microfiber towels.
Here's Jeff carefully wiping off the SONAX Polymer Net Shield using perfect technique...
:xyxthumbs:
Hi, my mane is Matias from Argentina, I would like to know the curing time for multi layer of this product if it is posible.
Thanks
