Sherif-- In your earlier posts you said "spraying 2-3 times on the applicator for each section." This could be what is causing you to have so much difficulty removing PNS. One spray on the applicator should be enough for each section.
Can this product be applied with a DA polisher? I'm curious whether it would make the difficulty in application a moot point.
I use a MF applicator when applying PNS. I find it works much better than foam (less drag, more even coat).
Looks like I have to try this method next time. Thanks for the insightrops:.
I may have missed where someone got back to you on this, but I'd hesitate on applying with a DA--from my experience it cures too quick to do so. Nothing stopping you from experimenting though!![]()
Next time I apply PNS, I'll try using a damp MF applicator. It should make application even easier. Not sure how much it will affect its durability, though.
With experience, applying/removing PNS becomes less of a pita, but it's still not what I'd call a user-friendly product.
What I do is prime a MF towel with Sonax BSD, not soak it, just get it damp, then spray PNS on that then wipe on (sometimes on the panel), I call this my wet towel then almost immediately wipe it off with another MF towel, I call this the semi-wet towel, finally buff the area with a dry towel. Works pretty well.
Maybe it's just me, but I can't reconcile the logic of adding anything to a product that isn't there from the manufacturer. Especially water, which is what you're trying to repel. Altering the chemical composition and ratios just doesn't seem like best practice to me.
I understand your thinking. I tend to agree with you. But, we all experiment around here, and sometimes it actually works out for the better. IMO, it's worth a try. If it seriously affects PNS's durability, then all that's lost is some time and a bit of product. When I say a damp applicator, I mean lightly damp (certainly not saturated or dripping wet). Just a little moisture which helps spread the polymers. If it works, it works...if not, no big loss.
Dampening the applicator with BSD shouldn't affect bonding as much as water, but water will likely spread PNS even easier since BSD doesn't spread that easily itself. Plus, its fairly thick consistency makes priming an applicator a bit more difficult than a light spray of water.
I wonder how much difference it really makes. Take Reload for instance. Doesn't Carpro recommend diluting it when working on darker colored vehicles? So instead of diluting it in the bottle using a damp towel should have the same effect. At least that's my thought on all this.
