BILL said:
Specifically,
Vanilla Moose Wax Hand Glaze removes those light swirls caused by washing and drying your vehicle. Typically, these swirl marks are high in number but low in severity. They happen because of a grain of sand caught in your wash mitt or a terry cloth towel that’s lost its softness. These blemishes are an easy fix.
Vanilla Moose Wax Hand Glaze contains gentle cleaners that blend away light swirls and mild oxidation on any type of paint. The cleaners eliminate the displaced edges of the scratch – this is dull, dead paint on either side of the scratch – to restore a level surface. Smooth, even paint will display crisper reflections and more radiant gloss.
On your vehicle’s chrome and glass, Vanilla Moose Wax Hand Glaze removes light swirls and clarifies the surface. It restores the smoothness and luster to hard plastic. The exterior of your vehicle may have become dull from sun exposure and oxidation but Vanilla Moose will bring it all back to life!
Vanilla Moose Wax Hand Glaze is designed for hand application, but it works great with your Porter Cable 7424, too. Use the white polishing pad or a gray finishing pad, depending on how much cleaning your paint requires. You can get great results by hand with the Pinnacle Polishin’ Pal and the gray or white 4 inch pads. Buff with a soft Cobra Microfiber Detailing Towel to eliminate the risk of micro-marring.
Vanilla Moose Wax Hand Glaze is an excellent, gloss-enhancing final step before applying wax. Even though there is some wax in this glaze, you’ll get better longevity if you follow up with ClearKote Moose Wax. The combination is brilliant on any paint finish!
Use ClearKote Vanilla Moose Wax Hand Glaze to remove light swirls and oxidation from your vehicle’s entire exterior. Glaze isn’t just for paint any more!
