On my Rupes 15, speed 5 and up to 6 are essentially the same speed. I do use the washer tweak.
Revisiting this (except on a 21)... I tried going to speed 5 and above for the first time and agree with you, there's no apparent change in the orbital speed (judging by sound) in the 5-6 range.
Does anyone have a 15 or 21 where you do hear an audible speed increase in the 5 to 6 range on the speed dial?
Mike P: if you're looking in, you've used multiples of each machine...have you noticed this same thing on all machines?
I wonder if this is just a case of the numbered dial is misaligned, and in turn if a part of the low end speed selection is cut off?
