Kycoralhead
- Jul 29, 2007
- 4
OK, I have tried Meg polish and I just received some XMT products which are thicker. So far it does not matter what I use, when I do a section and finish it and go to the next section I get splatter from the section I am working on to the section I just finished. Tiny drops thrown all over the place. Now mostly you can take a microfiber and wipe them off. What about using a product like a quick detailer to clean up the mess. It does work well. Also do you use a new pad each time you apply finish if you leave it from one evening to another? It is so hot in the garage, I have only been doing one section at a time. I put the pad in a plastic bag, but I have enough pads I could use a new one each time. Or does a pad get better the longer you use it. Thanks for the info
