How similar is Neverdull to steel wool?
Tried Neverdull on plastic chrome and it left a haze.How similar is Neverdull to steel wool?
Do you think wheel brightener is strong enough if two rounds of iron x didn't cut it?
Thats a good tip thanks Im going to try it.I have often been told brass wool (quad 0) is a better choice over steel wool as it doesnt leave some metal particles on surface. Anyone care to comment since brass wool is harder to find ??
-Yes.
1. Meg's Wheel Brightener contains Ammonia BiFlouride, which, when it comes in contact with moisture becomes: HF Acid...quite an effective 'cleaner; but, clearly, quite hazardous to one's health, to say the least!
2. IronX contains acetic acid (may morph into oxalic acid)...not nearly as harmful, or effective as a 'cleaner', as HF acid.
-And, I thought, IronX was used mainly as a: 'ferrous-contaminates remover/decon system'.
