read some of the threads so far and people seem to have been doing the same thing, either take your stuff inside during the winter, and hot summer days, or pray it stays good.
anyone here ever turn an old fridge into a sensitive products storage unit? i would assume that the insulation in the fridge would be good enough to keep everything at the upper end of the fridge's range, if you keep it in the highest setting (around 40-50 if it can get that high), you would be able to create a pretty decent temperature for a lot of materials to sit at.
but i wonder if just leaving the fridge off would help to keep things in a nice and low temp environment, use it as a nice temperature barrier container to the elements. that way you won't have to waste money on heating and cooling to keep the entire garage a good temp.
