Storing Foam Pads Wet with BFWD??
galaxy
Member
So, considering how difficult it is to remove BFWD from my black LC pads, what are your thoughts on storing the pad still wet with product in an airtight/zip-lock bag??
My 2nd time out, I changed things up a little to avoid the leftover. Used very little product to avoid over sturating the pad, and then as soon as i finished, i took it inside, used 2-3 drops of dawn, agitated, and rinsed, squeezed, rinsed and got 99% of it out.
Id not ziplock them.
After correcting my car and cleaning the pads, I put them in zip lock bags and didnt fully seal them thinking the moisture would evaportate and leave the bag keeping them safe.
All they did was condense at the top of the bag, kept the pad moist for 2-3 months and started to mold.
I've already been ziplocking my pads for some time now with no moisture in the bags. I let them thoroughly dry before closing them up though. I started doing this because my pads (white LC especially) were changing colors. The texture of the white ones actuallly felt different to the touch once they changed also. Plus, I thought my idea would eliminate priming the pad next time I need it for the WD. Oh well.
I may try it if I know it's going to be a relatively short time between use and then clean well for longer storage.
I probably use too much product, I'm sure...but I've always tried to clean right after use with Dawn and getting all the WD out has been a bear. I even let it soak for a bit with no improved results.
do not seal in a ziploc bag it will mold. I ruined 2 pads by doing this. I even tried putting the applicator in the bag with BFWD (not washing off) and it still grew black fuzzy mold, and that was with no water/moisture added.
Now I just put the pads in a small plastic drawer storage bin. it's not air tight and hasn't molded yet but still keeps the dust off the pads.
This is actually a pretty common way to temporarily store the pads while wet. I do the same thing with paint brushes when painting indoors or outside too...:props:
could freeze the BFWD pads, but it might make the stuff separate while on the pad causing a mess. my grandfather always stored his used paint brushes in the freezer instead of cleaning them out, especially if he knew he was going to be using that brush again soon. was a great idea i still use to this day.. my dad used it, now i use the same method lol...
