Never really used Iron Decon before. I've always just relied on clay. However i recently decided to pick a gallon of Meguiars D1801 Iron Decon up to give it a proper prep before doing a paint correction. Sort of wishing i hadn't now. The stink is pretty bad. Just wondering where you guys store your Iron decon ? I typically store my gallon jugs inside the home, cos it gets so hot in the garage. I live in Florida so the heat can get pretty high in the garage.
Also do the vapors from the bottle attack any metals around where it's stored over time ? I used to keep my pool chemicals, as in Chlorine and Muratic Acid in the garage, til it started rusting everything out around it. Just wondering if Iron Decon will attack / corrode if i leave it in my garage storage. Which are all Craftsman metal storage cabinets. I'm guessing probably no, and chlorine and muratic acid is a 1000x more corrosive, but iron decon is designed to dissolve metals in clear coat, so i'm not putting it out of the equation.
Anyway looking for some storage idea's. House is a no-go, and i don't want my garage to stink like a crapper !
