Most planes are painted single stage white because the pigment used to create white is titanium dioxide powder and this makes the paint hard and also more resistant to deterioration than other colors/pigments.
It will oxidize however and when it does it becomes chalky and dry and yes it will absorb oils, solvents and other liquids.
When paint is oxidized it's important to really do a thorough job of compounding it for a uniform appearance, otherwise you can see dull spots and shiny spots, places you didn't get all the oxidation off and places where you did get all the oxidation off.
warrior151 said:
Used Megs Heavy Cut Cleaner (so, so result)
If you're referring to M04, it's an aggressive compound similar to M49, (I think), which is a heavy oxidation remover in the Marine Line. This product is actually pretty good at removing oxidation when used with a rotary buffer, used with a Cyclo you're results would be very dependent upon aggressive foam cutting pads, even wool pads.
warrior151 said:
3M Rubbing Compound (again not a great result)
This too is a very aggressive compound and if this isn't working any better than the M04 Heavy Cut Compound that starts to form a trend that indicates a problem that might not be related to which compound you use.
Again the type of pad would be a huge factor the the effectiveness of either of the above products.
Just to double check, when you buff on your plane's paint you're seeing white pigment or white paint come off and onto the pad right?
If not that would mean you plane has a clear coat finish but I don't think that's the norm in this industry for production coatings. (Has the plane been re-painted?)
warrior151 said:
The above two products are SMAT products and polish just about any material or coating they're used on so if they're not working, the M04 isn't working and the 3M HDC isn't working, again, this is a trend that points to a problem not related to the abrasive products being used or the manner in which they are applied.
Question: So any areas you buff on buff to a clear, high shine?
For example areas under the plane not exposed to full sun and weather all the time?
One thing I do when I run into a problem is work a smaller section and really work it good, the idea being to see if lots of work to a small area gets you any gains at all. If it doesn't then lots of work to the entire plane isn't going to work either.
One more thing... we're only talking about the Test Spot? You didn't compound the entire plane twice only to find out you're not getting the results you want?
Pictures?
icture:
