You should remove old wax after 3 months and relayer from the beginning again simply because it will yellow and have become deteriorated through UV damage, as well as picking up contaminants and dirt in its surface that shampoos won't shift. It's like keeping the bath water for 3 months. At some point you gotta pull the plug and put in fresh water.
just repolish it... the polish will easily strip the LSP
Ok, so I was thinking the exact same thing as I have only applied sealant at this time. I'm not totally happy with my first attempt of polishing so I want to remove the sealant and reapply M205.
Dom Colbeck, the owner of Dodo Juice, proposes a basic rule: Depending on how often the vehicle is used, whether it is garaged or not, and what kind of pollution and contaminants it is exposed to, strip the wax two to four times a year.
There are plenty of "Paint Cleaners", both abrasive and non-abrasive, that will effectively remove any previously applied wax or paint sealant and after removing the paint cleaner, (or mild cleaner/polish in the case of a product like M205), that after removal, the paint will look clear and glossy. That's working forward in the process.
Pinnacle and P21S Paintwork lotions are a guys/girls best friend.
But they have fillers...
But why does that matter? Presumably if one is using a paint cleanser, one is not intending to follow it up with paint correction. And if one is intending to do paint correction, is it really necessary to remove all previously applied wax. Won't the polishing do that anyway?
:iagree:but, back to the op post on stripping wax and sealant for what ever reason. Cheap and effective= DawnBut why does that matter? Presumably if one is using a paint cleanser, one is not intending to follow it up with paint correction. And if one is intending to do paint correction, is it really necessary to remove all previously applied wax. Won't the polishing do that anyway?
